1Back to top Go down   Aftermarket Clutch/Brake Levers? Empty Aftermarket Clutch/Brake Levers? on Sun Oct 20, 2019 3:46 pm
tjh1985
tjh1985
Does anyone know of any aftermarket clutch (and matching brake lever) that the clutch cable lever nipple will fit WITHOUT having to drill/shave the lever to make it fit?
Aftermarket Clutch/Brake Levers? 15715910
http://www.thomashurst.com
2Back to top Go down   Aftermarket Clutch/Brake Levers? Empty Re: Aftermarket Clutch/Brake Levers? on Tue Nov 19, 2019 4:24 am
@gorio wrote:I would love some modern levers as well but there seems to be none around fir these bikes.
Here is the link to a thread indicating one remodeler's use of Ducati Monster hand levers, front master cylinder and switch gear on his K75. Perhaps you should contact him for more information.
1995 K75 73,000 miles
Aftermarket Clutch/Brake Levers? Usa-lo10
3Back to top Go down   Aftermarket Clutch/Brake Levers? Empty Re: Aftermarket Clutch/Brake Levers? on Tue Nov 19, 2019 7:11 am
If the clutch nipple is the only real problem, get a bit of brass bar of the right diameter and make your own. I keep various diameters of brass just for odd jobs like that.
'78 Moto Guzzi 850-T3, '79 Moto Guzzi 850-T3 California,'93 Moto Guzzi 1100ie California
4Back to top Go down   Aftermarket Clutch/Brake Levers? Empty Re: Aftermarket Clutch/Brake Levers? on Tue Nov 19, 2019 3:05 pm
@gorio wrote: I still find it odd that with the number of these bikes out there someone hasn't made an aftermarket adjustable lever.
There are aftermarket adjustables and there are both electronic and mechanical thumb-operated shifters of which this is just one example.
5Back to top Go down   Aftermarket Clutch/Brake Levers? Empty Re: Aftermarket Clutch/Brake Levers? on Tue Nov 19, 2019 3:21 pm
K1200's had a hydraulic clutch. Probably not the simplest solution but with a bit (lot) of McGyvering it would also be possible to go Mechanical/Hydraulic retaining the OEM lever and modifying the OEM cable to attach to a hydraulic master cylinder.
6Back to top Go down   Aftermarket Clutch/Brake Levers? Empty Re: Aftermarket Clutch/Brake Levers? on Wed Nov 20, 2019 10:00 am
@gorio wrote:
@Laitch wrote:There are aftermarket adjustables and there are both electronic and mechanical thumb-operated shifters of which this is just one example.
My foot still works for gear selection.
That's a blessing anyway. Clearly, I'm not the consultant for this modification because of my inability to differentiate hand problems from foot problems. Smile
I will observe that Martin could be on the right track suggesting a hydraulic clutch adaptation or a motorcycle with such a clutch might be the most effective choice if improvement of your left hand's mobility is in doubt.
7Back to top Go down   Aftermarket Clutch/Brake Levers? Empty Re: Aftermarket Clutch/Brake Levers? on Wed Nov 20, 2019 1:12 pm
Gorio changing levers is not just a simple matter. There are all sorts of things to worked out like pivot points, lever lengths and ratios. If you change the clutch lever travel by moving the lever closer to the bar the amount of travel is reduced which will not allow proper activation of the clutch. So in order to get back the travel reduction you have to change the lever length at the other end. Without correctly calculating and changing the lever length at the both ends could end up with a harder pull. Brake lever travel distance can be less of an issue and travel can be reduced slightly. The easiest way to reduce the amount of effort and keep the movement required to properly activate the clutch would be to go hydraulic or hydraulic slash mechanical. Calculations for lever lengths to do this conversion are still required.
8Back to top Go down   Aftermarket Clutch/Brake Levers? Empty Re: Aftermarket Clutch/Brake Levers? on Thu Nov 21, 2019 11:30 pm
Flanders makes (or at least used to make) an aftermarket clutch lever but it's just an exact clone of the factory clutch lever.
