1Back to top Go down   Electrikary Empty Electrikary on Sat Oct 26, 2019 11:07 am
Stumpy
Stumpy
I have been riding my k and enjoying every minute. On my last ride the bike ran well until I was returning home, at 50mph and above 3000 rpm,  the bike started to misfire and stalled, when running at normal traffic speed of 20/30 mph the bike ran fine. I did have my lights on, and when I got back to the garage, I put the battery back on charge.
BMW K100RT 0095857
2Back to top Go down   Electrikary Empty Re: Electrikary on Sat Oct 26, 2019 11:18 am
brickrider2
brickrider2
Is the fuel filter clogged and passing insufficient fuel?
You seem to have determined the source of the poor running is electrical, but why?  Have you had this problem in the past?
Which model are you riding?   Exclamation
1996 K1100LT
3Back to top Go down   Electrikary Empty Re: Electrikary on Sat Oct 26, 2019 11:59 am
What is the condition of the four pin tank connector?  They are known to cause problems when running from the vibrations and dirty/loose pins.
4Back to top Go down   Electrikary Empty Re: Electrikary on Sat Oct 26, 2019 1:51 pm
Stumpy
Stumpy
@Point-Seven-five wrote:What is the condition of the four pin tank connector?  They are known to cause problems when running from the vibrations and dirty/loose pins.
The connection is good, I keep it clean and tight fitting.
BMW K100RT 0095857
5Back to top Go down   Electrikary Empty Re: Electrikary on Sat Oct 26, 2019 1:54 pm
Stumpy
Stumpy
@brickrider2 wrote:Is the fuel filter clogged and passing insufficient fuel?
The fuel system has been replaced, new mounts and fuel pump and new filters. My bike is a 1988 K100RT. The problem has been there since I got the bike, recently it has got worse.
BMW K100RT 0095857
6Back to top Go down   Electrikary Empty Re: Electrikary on Sat Oct 26, 2019 4:37 pm
volador
volador
Starter motor cleaning? Ignition switch cleaning? Temp sensor condition?
7Back to top Go down   Electrikary Empty Re: Electrikary on Sat Oct 26, 2019 5:12 pm
@Stumpy wrote:The problem has been there since I got the bike, recently it has got worse.
Have you checked the condition and attachment of the z-hose breather that runs from the crankcase to the air box on the left side of the engine. Have you checked the rubber intake manifolds on the throttle bodies for leaks using carb cleaner or propane while the engine is running? An engine with air leaks might perform acceptably at low revs but lean-out and stumble under load.
1995 K75 73,000 miles
Electrikary Usa-lo10
8Back to top Go down   Electrikary Empty Re: Electrikary on Sat Oct 26, 2019 8:33 pm
Fuel filter is the first thing I would check and if you don't know when it was last replaced then replace it.
9Back to top Go down   Electrikary Empty Re: Electrikary on Sat Oct 26, 2019 9:11 pm
Stumpy
Stumpy
No one has got close, it is the regulator/ rectifier, the brushes are knackered.
At low revs the voltage was 13.7 at high revs the voltage was 12.9. I have just put the new one on the bike,I have not yet been out to check it but with everything else that I have replaced and repaired, I am confident that this was the problem.Electrikary 41097210
BMW K100RT 0095857
10Back to top Go down   Electrikary Empty Re: Electrikary on Sat Oct 26, 2019 11:22 pm
volador
volador
Twas my next reply. Approx. how many thousand miles on that VR?
11Back to top Go down   Electrikary Empty Re: Electrikary on Sun Oct 27, 2019 5:42 am
Stumpy
Stumpy
@volador wrote:Twas my next reply. Approx. how many thousand miles on that VR?
My bike has 50410 miles, they look like the original set. I am going to clean the housing and replace the brushes for future use.
BMW K100RT 0095857
12Back to top Go down   Electrikary Empty Re: Electrikary on Sun Oct 27, 2019 10:44 am
I'm a firm believer that the voltage regulator can be the source of running problems and shouldn't be overlooked when all else fails.  I had a 16 valve K100 that would die when coming down to idle from a high speed run.  After over a year of checking everything in the engine controls the problem was solved when the voltage regulator was replaced.
The engine controls rely on adequate electrical power.  When all else fails to correct a driveability issue, replace the voltage regulator.  Fortunately, they are not terribly expensive or difficult to replace.
