1Back to top Go down   Strange problem in start Empty Strange problem in start on Sat Nov 02, 2019 3:18 pm
Mascarenhasrf
Mascarenhasrf
Hi All,
my bike latelly is doing a strange thing, whitout tha AFM plug connected the bike starts and works fine. As soon as i plug the AFM it dies.
ive tested all the pins in the AFM and i know that only when the pin8 is connected that the bike dies! whit pin 5, 9 and 7 bike is running!
ive changed the AFM for a used but in good condition ( or at least im using the words from the seller) but still the same issue.
Maybe ive got a ECU problem?
Glad to have your opinion, and sorry for my english Smile
2Back to top Go down   Strange problem in start Empty Re: Strange problem in start on Sat Nov 02, 2019 9:08 pm
Please put your motorcycle's year and model in the Signature section of your Profile so it will show up under every post you make.
1995 K75 73,000 miles
Strange problem in start Usa-lo10
3Back to top Go down   Strange problem in start Empty Afm on Sun Nov 03, 2019 4:36 am
daveyson
daveyson
If you search BMW k100 AFM you will find Bosch AFM restoration and other links. If both are faulty you may be able to replace the one you bought.
4Back to top Go down   Strange problem in start Empty Re: Strange problem in start on Sun Nov 03, 2019 10:27 am
Mascarenhasrf
Mascarenhasrf
Hi,
i followed all those links, and for sure i start to think that the problem is in the jetronic ECU, all the readings in both AFM are in range, and the bike starts and idles good without the AFM plugged in. when i plug the AFM plug the bike stalls... so i think the problem is in the ecu... damn thing...
Thanks for the advice
BMW K100 Cafe Racer
1986
5Back to top Go down   Strange problem in start Empty Re: Strange problem in start on Sun Nov 03, 2019 11:56 am
MAF going faulty usually means a huge increase in fuel consumption....but it usually still runs. Been there.
MAF not fitted I think usually means non running bike.
FICU under the seat is more likely fault.
Can you swap FICU with someone as a test? Anyone near you? Any 2v K100 will swap. K75 and K100 are not interchangeable but no difference in the years.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
