1Back to top Go down   Bridgestone T31 Tires Empty Bridgestone T31 Tires on Tue Nov 05, 2019 7:05 pm
brickrider2
brickrider2
After reading the reports on fitting Bridgestone T31 tires on K-bikes, I bought a pair.  I'm now in the process of changing them out for their replacement.  I liked their performance; they made the bike handle as if it had lost 100 lbs.  However, they have surprised me in ways I never anticipated.  The front and rear tire wear at virtually the same rate.  In the past I've replaced two rear tires before one front was knackered.  That was my experience on other motorcycles. Now, at about 10 k miles I am again fitting T31 tires on both ends of the bike.  Is this typical of this tire?  A second surprise is the wear pattern of the front tire.  It's badly cupped.  Any thoughts on what caused that condition?
1996 K1100LT
2Back to top Go down   Bridgestone T31 Tires Empty Re: Bridgestone T31 Tires on Tue Nov 05, 2019 7:10 pm
I have used BT45 and not familiar with BT31 but the front would scallop very quickly unless run at higher pressures, I runt the front at 38 psi and its ok at that.
10k miles is good but the front wear rate suggests its a dual compound or softer tyre meaning you might need to look at the pressure you run it at.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
3Back to top Go down   Bridgestone T31 Tires Empty Re: Bridgestone T31 Tires on Tue Nov 05, 2019 8:57 pm
What pressure are you running the front at?  38psi is what I run all my front tires at, and have never had a cupping problem.  I'm pretty sure that is the pressure listed in the owner's manual.
4Back to top Go down   Bridgestone T31 Tires Empty Re: Bridgestone T31 Tires on Tue Nov 05, 2019 10:34 pm
brickrider2
brickrider2
I use 38/42psi. front/rear.
In the more remote parts of Arizona that I rode through in October there were significant stretches of what approaches "washboard."  I found the forks did a pretty good job of taming that, but maybe the front tire suffered.
1996 K1100LT
5Back to top Go down   Bridgestone T31 Tires Empty Re: Bridgestone T31 Tires on Tue Nov 05, 2019 10:38 pm
I've run lots of T30/EVO fronts at 35-36 front and 40 rear and the front tread wears just fine without cupping.
And the rears do wear faster but that may have something to do with how I ride. Very Happy
6Back to top Go down   Bridgestone T31 Tires Empty Re: Bridgestone T31 Tires on Tue Nov 05, 2019 11:29 pm
An out of balance tire will have strange wear patterns(cupping and flat spots).  I have found that my wheels do not have the heavy spot at the valve stem.  Installing tires with the red dot oriented with the valve stem has led to weird balancing and odd wear issues.
I now check the bare wheel for the heavy spot before I mount the tire.  Makes balancing a lot easier, and the tires seem to run smoother with less vibration.  I've found that my three spoke wheels have a heavy spot about 60 degrees from the valve stem and can need as much as an ounce of weight to balance.
7Back to top Go down   Bridgestone T31 Tires Empty Re: Bridgestone T31 Tires on Tue Nov 05, 2019 11:45 pm
@brickrider2 wrote:I use 38/42psi. front/rear.
I run the same pressures and have Ks going back 10 years and found these are the best too.
8Back to top Go down   Bridgestone T31 Tires Empty Re: Bridgestone T31 Tires on Wed Nov 06, 2019 4:08 pm
brickrider2
brickrider2
I doubt very much that incorrect tire pressure is the reason for the cupping of the front Bridgestone tire.  It's more likely that the balance was not the best.  However, that theory has it's own problems, as an out of balance tire can be felt by the rider, but the bike ran very smoothly.  scratch As I mentioned, I've replaced it with a second T31.  It'll be interesting to see if the second one wears any differently.  It could very well come down to the formulation of the rubber and the condition(s) of the roads I travel.  We shall see.
1996 K1100LT
