1 [solved]Frame/engine mount Tue Oct 29, 2019 10:14 pm
tinyspuds
Hi all,
Spent the day divorcing my sidecar from the K, dropping the sub frame and removing the trans for a spline lube. Found heavy oil soiling in the bell housing so Im assuming I have a leaky main seal - but that can wait a few days.
The side car subframe shares the OEM engine/frame mounts at the front and uses an8mm 10mm allen head bolt (not the fancy cap loc bolt).
This bolt (LH side) spins easily but will neither tighten nor back out. It feels like its stripped or sheared) but it wont extract with a magnet or with me pulling on the (otherwise unfastened) subframe.
Does anyone know if the engine case hole is directly threaded or is there a threaded interference fit bush inside the hole that may have come loose or possibly even, does it sound like a failed helicoil?
Last edited by tinyspuds on Tue Oct 29, 2019 11:16 pm; edited 1 time in total (Reason for editing : thanks to Glenn)
