1Back to top Go down   Won’t start and flooding Empty Won’t start and flooding on Mon Nov 18, 2019 4:59 pm
Wally!
Wally!
Hello guys 1st ask since joining.
So just got my project a 1987 k100rt it turns over starts but then floods with in seconds and wont start again.
The guy I bought it off has changed the ignition lines, fuel regulator and  fuel pump to try to fix it but non of this worked. This evening I have checked there is a spark at all plugs and the leads are in the correct order. I do have short clip of it flashing up but not sure how to load it up on here.
Any advice with the bike would be great as I have been told these are amazing reliable bikes.
Many thanks
1987 K100RT project on the go
2Back to top Go down   Won’t start and flooding Empty Re: Won’t start and flooding on Mon Nov 18, 2019 5:24 pm
Check the temperature sensor and its connection. A faulty sensor or bad connection can cause flooding. There is a table showing the correct correlation between water temperature and resistance in Ohms.
Regards Martin.Won’t start and flooding K100_t11
3Back to top Go down   Won’t start and flooding Empty Re: Won’t start and flooding on Mon Nov 18, 2019 6:36 pm
Is there any chance the injectors are stuck open?  How long has it been since the bike was in regular use?
4Back to top Go down   Won’t start and flooding Empty Re: Won’t start and flooding on Mon Nov 18, 2019 6:45 pm
@Wally! wrote: I do have short clip of it flashing up but not sure how to load it up on here.
Upload it to YouTube then post its URL link here.
1995 K75 73,000 miles
Won’t start and flooding Usa-lo10
5Back to top Go down   Won’t start and flooding Empty Re: Won’t start and flooding on Mon Nov 18, 2019 9:22 pm
Additional the TPS and or the AMF could be corroded if it has been sitting
The best  start is working thought the fault finding flow chart
1986 K100 RS Motorsport
#### K100 RS Project
2011 R1200 GS
6Back to top Go down   Won’t start and flooding Empty Re: Won’t start and flooding on Tue Nov 19, 2019 7:59 am
Wally!
Wally!
@Matthew-Brisbane wrote:Additional the TPS and or the AMF could be corroded if it has been sitting
Sorry where would I find one of these?
7Back to top Go down   Won’t start and flooding Empty Re: Won’t start and flooding on Tue Nov 19, 2019 1:14 pm
@Wally! wrote:Sorry where would I find one of these?
Click on this link. Then click I agree. Look near the bottom of the column labeled Electrical and click on the link Troubleshooting the EFI.
8Back to top Go down   Won’t start and flooding Empty Re: Won’t start and flooding on Tue Nov 19, 2019 6:09 pm
Wally!
Wally!
Very helpful thanks
9Back to top Go down   Won’t start and flooding Empty Re: Won’t start and flooding on Tue Nov 19, 2019 7:26 pm
If you are checking the temperature sensor also check it was not fitted with PTFE tape, it must be metal to metal. If not it will give overfuelling.....
Also check fuel connections are correct and not reversed.
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 100,380 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell No 33,600 miles
10Back to top Go down   Won’t start and flooding Empty Re: Won’t start and flooding on Wed Nov 20, 2019 5:03 pm
Welcome to the forum
Wally are you the Navy bloke from Facebook  ?
2011 R1200 GS
