Cat on Non-cat bike on Tue Nov 26, 2019 3:43 pm
gorio
As I search for a solution to my broken exhaust (1992 K100rs non-Cat) I seem to come across several K1100lt exhausts with Cat.
They are a bit newer, a bit lower mileage and generally lower priced which is important at the moment.
I don't mind running a cat and doing my bit for cleaner air but will it work properly without an ECU change so I can plugin the O2 sensor?
If I run sans O2 sensor will I end up plugging up the Cat and causing issues?
Any experience with this?
I know the after market exhaust are out there I just don't want to spend the money at the moment. Thought about re-welding but the re-weld that is there now was likely done without purging the exhaust system with Argon so there will tungsten oxide deposits which in my mind is what causes the failure of the re-welds from the inside out.
I may still just end up re-enforcing the area at the collector and hoping for the best.
1992 k100rs for fun
2006 r1200rt for heavy lifting
