1Back to top Go down   Flasher Module Problem Empty Flasher Module Problem on Mon Dec 30, 2019 11:01 pm
The Flasher module on a recently acquired '88 K100RS SE has a problem with the right turn signals.
Operation of the left turn signals is correct, the left handlebar switch turns them on and the cancel switch on the right cancels them.
The hazard flasher switch works normally as well.
The problem is that the right handlebar switch turns on both right and left turn signals, and the cancel switch cancels them.
I have replaced the module with one from another bike and the signals all work properly.  When I take the faulty module to another bike the same problem happens on that bike.
As far as I can troubleshoot, the relays and the relay drivers are working properly, beyond that, I can't seem to figure out what is going on because of those 10 pin strips on the circuit board.  I have purcased a replacement, but at the price of these things, I would really like to fix it and put it in my spares stash.
Anybody seen this problem and fixed it?
2Back to top Go down   Flasher Module Problem Empty Re: Flasher Module Problem on Tue Dec 31, 2019 1:56 am
That problem is the same as when fuse #7 is open circuit so it may be the tracks on the board that carry that power that are broken or dry solder.
3Back to top Go down   Flasher Module Problem Empty Re: Flasher Module Problem on Tue Dec 31, 2019 10:06 am
RickG,Thanks, I just looked at the circuits connected to pin #15 and the solder joints are good with the traces having conductivity and all the diodes working properly.  I guess it's back to the drawing board.
4Back to top Go down   Flasher Module Problem Empty Re: Flasher Module Problem on Tue Dec 31, 2019 3:10 pm
Try multimeter comparison readings between the good one and the bad one.
Happy New Year regards Martin.
5Back to top Go down   Flasher Module Problem Empty Relay on Tue Dec 31, 2019 3:17 pm
daveyson
daveyson
Does anything look overheated?  Maybe post photos.
6Back to top Go down   Flasher Module Problem Empty Re: Flasher Module Problem on Tue Dec 31, 2019 4:27 pm
Nothing is burnt or out of the ordinary.  All solder joints are good.
I have spent at least an hour looking at the board through a 10x magnifier and haven't seen anything that could be causing a problem.
I have tested the function of all the diodes on the board and as far as I can tell they are all okay.
Because of those 3 white 10 pin terminal strips on the board I can't really trace the circuitry to see where things go.  Makes it hard to figure out what the circuit is doing.
I am getting some bizarre resistance readings around the 4093 IC(every pin has some continuity to every other pin).  Since it's a CMOS device and static sensitive and cheap to replace, I have ordered a replacement and should have it next week.  Until then, I am hoping that RBM will chime in with a suggestion or two.
Because of the CMOS stuff on the board, I'm hesitant about poking around in a good module.
7Back to top Go down   Flasher Module Problem Empty Relay on Tue Dec 31, 2019 6:08 pm
daveyson
daveyson
I have a spare flasher with a broken relay contact, I just got the same results for that IC
Only two of the readings were constant, the others were momentary.
8Back to top Go down   Flasher Module Problem Empty Re: Flasher Module Problem on Tue Dec 31, 2019 7:37 pm
if measuring anything cmos
make sure that the ground pin = common  is connected to an earth some where , then whatever will be safe
if the ic has a "b" after it, (suffix ) IT IS A BUFFERED VERSION AND IS QUITE RESILIENT .. often found with suffixes "b p "
good luck
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OFlasher Module Problem Au-log10
9Back to top Go down   Flasher Module Problem Empty Relay on Tue Dec 31, 2019 7:41 pm
daveyson
daveyson
Good to know, it does have BP at the end,  at least mine does.
10Back to top Go down   Flasher Module Problem Empty Re: Flasher Module Problem on Tue Dec 31, 2019 8:19 pm
Yes, it's buffered.  And the replacement is buffered as well.
I am suspecting that something internal to the IC is triggering both multivibrators when the right side is activated.  At least I hope so.  All the diodes surrounding the IC look to be okay, at least without pulling them all to test them away from the board.  I have to admit that my component level troubleshooting leaves a lot to be desired.
11Back to top Go down   Flasher Module Problem Empty Relay on Tue Dec 31, 2019 9:32 pm
daveyson
daveyson
Maybe something is supposed to cancel the left, but not working, just guessing.
12Back to top Go down   Flasher Module Problem Empty Re: Flasher Module Problem on Tue Dec 31, 2019 11:23 pm
Probably right about that, but the schematic is almost useless for figuring out what is going on.  Those 10 pin arrays make it impossible for me to trace the circuits.  It's supposed to be a couple of astable multivibrators, one for each side, but the circuits as shown don't make sense to me.
