1Back to top Go down   wiring early tank connector Empty wiring early tank connector on Tue Jan 07, 2020 11:41 am
nino
Hello, I need help with wiring on undertank connector on early K. I made mistake on reconnecting broken wires on tank connector. Now I can hear fuel pump but no fuel out of tank.
Anyone to explain wiring layout (by wire colors) on connector. Thanks
2Back to top Go down   wiring early tank connector Empty Re: wiring early tank connector on Tue Jan 07, 2020 11:56 am
Green/white is +12V to the pump, brown is -
This is for the naked early K100.
Green/black is +12V to the pump, orange is -
This is for the early K100 RS/RT.
wiring early tank connector Eu-log10  K1100RS/LT - R1200RT - R1100RS (RIP) - Cagiva SST 350 Ala Verde
3Back to top Go down   wiring early tank connector Empty Re: wiring early tank connector on Tue Jan 07, 2020 6:24 pm
nino
Thanks Arlina, but there are four wires on connector. I need position on connector of each of it
4Back to top Go down   wiring early tank connector Empty Re: wiring early tank connector on Tue Jan 07, 2020 6:36 pm
Position, I dunno....
Haven't got an old loom here Smile
Should be color on color.
What K and year you have?
5Back to top Go down   wiring early tank connector Empty Re: wiring early tank connector on Thu Jan 09, 2020 5:38 am
nino
I solved the problem somehow. Instead old burned connector I installed microphone 4 pin plug. Thanks
