1Back to top Go down   K1100LT Brake Hose Empty K1100LT Brake Hose on Thu Jan 09, 2020 7:26 pm
brickrider2
brickrider2
I've been told that it's possible to pull the wiring away from the frame tube to access the point where the rubber hose from the master cylinder joins the steel tube that runs to the ABS pump.  I haven't been able to do that -- not even close.  I cut the plastic ties and pulled all the wiring harness away from the frame that I could, but I can hardly see the connection point, much less access it with a wrench.  My questions are: has anyone here actually replaced that hose?  How?  Must one remove the radiator and gain access from below the headstock? TIA
1996 K1100LT
2Back to top Go down   K1100LT Brake Hose Empty Re: K1100LT Brake Hose on Thu Jan 09, 2020 11:03 pm
Removing the radiator would be of no help.
Undo the bracket that holds the lines down - red arrow.  Blue circle is the connection.
K1100LT Brake Hose PP3ys2c
3Back to top Go down   K1100LT Brake Hose Empty Re: K1100LT Brake Hose on Fri Jan 10, 2020 12:42 am
brickrider2
brickrider2
Thanks Drake.  May I ask what bike appears in the photo?  My 1995 K1100LT does not look like that.  I can just make out the metal bracket, but there is a rubber or plastic hood in that area that shields the brake line.  I cannot budge it and I cannot see how it is fastened down to the frame tube(s).  Very odd.  Maybe this is some bizarre modification the P.O. made to the bike. (?) I recall it came to me with a lot of "extra" wiring for the OEM alarm system.  It seems improbable that the factory would turn out something that seemingly defies accessing if brake lines should be changed out after X years.
K1100LT Brake Hose Image010 K1100LT Brake Hose Image010
Last edited by brickrider2 on Fri Jan 10, 2020 11:27 am; edited 1 time in total (Reason for editing : add pix)
1996 K1100LT
4Back to top Go down   K1100LT Brake Hose Empty Re: K1100LT Brake Hose on Fri Jan 10, 2020 1:00 am
That's a K1100RS but the metal pipe from the ABS control unit is the same part on RS and LT bikes (34322332027) so it should end at the same place.
5Back to top Go down   K1100LT Brake Hose Empty Re: K1100LT Brake Hose Yesterday at 8:51 pm
brickrider2
brickrider2
I took advantage of our recent fine weather and wheeled the bike out into the bright afternoon light.  That made all the difference in the world!  I located and removed some ties that had previously prevented me from accessing the connection between the solid steel brake line and the flex line.  That pesky old front brake line has now been replaced.  I thereafter pulled the ABS computer/pump to send off for repair.  Honestly, that was an SOB of a job!  Made me wonder how anyone can seriously assert working on a (K1100LT) K-bike is simple. That ABS unit is tucked down in the innards in such a way that almost defies removal.  I now am hoping I will be able to reinstall it without kinking the hard lines, which need to be navigated in order to lower the ABS units back in the tray.
1996 K1100LT
6Back to top Go down   K1100LT Brake Hose Empty Re: K1100LT Brake Hose Yesterday at 9:18 pm
The metal lines are fairly flexible. You can move them around a fair amount without damaging them. (Of course I'm careful and never bend them any more than necessary.)
When doing a spline you can just strap the ABS control unit to the frame so it doesn't have to be removed.
