Number of posts : 7867
mike d wrote:If the alternator is working and you get good DC volts across the battery, then have you check for parasitic drain when the engine is switched off?
It could be that it is draining the battery a bit overnight, causing the poor starting in the morning.
Mike
Put a meter on it, it will show if you have a parasitic drain.
If you have, pull the fuses one at a time and watch what happens as you take out each fuse.
If you still have a parasitic drain pull the relays one at a time carefully watching what happens as you pull each relay.
That will tell you what circuit is your problem. Or it if its a faulty relay.
If you still have a parasitic drain pull/disconnect the Regulator...it can also cause one.
1971 Yamaha 125 YAS-1
