1Back to top Go down   bit inside gas cap nose -- 1990 K1 Empty bit inside gas cap nose -- 1990 K1 Fri Feb 21, 2020 10:01 pm
bldrhouse
bldrhouse
this is a photo of the gas cap when flipped over.
The "nose" is the conical piece; inside that conical there is what appears to be a pressure valve of some kind. Since it popped out when I got the nose off, I'm not sure which way it goes back in -- see pic 2 and 3, and not sure where the small flat gasket goes: on top or underneath?  Regular K bikes don't seem to have this bit.
http://forum.kforum-tech.com/members-upload/uploads/GAS_CAP_BITS_CONFUSION.docx
YOU'LL HAVE TO DOWNLOAD DOCUMENT TO VIEW QUESTION ON IT
thanks,  zk
Last edited by bldrhouse on Fri Feb 21, 2020 10:02 pm; edited 1 time in total (Reason for editing : correction)
2Back to top Go down   bit inside gas cap nose -- 1990 K1 Empty Re: bit inside gas cap nose -- 1990 K1 Fri Feb 21, 2020 10:22 pm
All I get is code at that link. Anyway, watch this.
3Back to top Go down   bit inside gas cap nose -- 1990 K1 Empty Re: bit inside gas cap nose -- 1990 K1 Fri Feb 21, 2020 10:42 pm
bldrhouse
bldrhouse
Laitch wrote:All I get is code at that link. Anyway, watch this.
thanks; used that for rebuild, but interior of K1 cap is different than the K100 cap. It has interior bits that are the issue, and not in that vid.
cannot post pix since not enough posts..
will send directly to you if you email me at zigyphoto@gmail.com
4Back to top Go down   bit inside gas cap nose -- 1990 K1 Empty Re: bit inside gas cap nose -- 1990 K1 Fri Feb 21, 2020 11:05 pm
The interior of your K1's cap is different, but the K1, and later model K100/K75 caps all have the same part number. An earlier cap may have replaced your original. The earlier caps have been indicated by BMW to be prone to vapor lock.
Somebody with a K1 here will clear this up for you as soon as you post some photos.
5Back to top Go down   bit inside gas cap nose -- 1990 K1 Empty Re: bit inside gas cap nose -- 1990 K1 Fri Feb 21, 2020 11:10 pm
bldrhouse
bldrhouse
Yes, cap itself is not the problem; the issue is those interior bits, which don't appear in the vid https://www.euromotoelectrics.com/product-p/ft-gasketkit461.htm  when he removes the conical cap..
I await the wisdom of a K1 rider....
thanks for your good ideas and help.
Aren't we motorcyclists a fine community?
z
The K1 gas cap is exactly the same, internally and externally, as the other Ks.
(The gas tank is the same too.)
The docx file downloaded fine for me.
Here's where the O-rings go - I lifted them out of place for the picture to make them easier to see.
bit inside gas cap nose -- 1990 K1 UXzYAXu
bldrhouse
bldrhouse
duck wrote:Here's where the O-rings go - I lifted them out of place for the picture to make them easier to see.
Thanks!  the top picture shows me almost exactly what I needed to know -- but issue is not the o-rings; it's the little spring and white capped gizmo on top.  There is a small circular gasket (not o-ring) that I believe fits UNDER the piece on which the spring sits?
z
This gasket? It goes under this piece:
bit inside gas cap nose -- 1990 K1 Nss8Mgq
10Back to top Go down   bit inside gas cap nose -- 1990 K1 Empty THANK YOU THANK YO! Sat Feb 22, 2020 3:05 pm
bldrhouse
bldrhouse
duck wrote:This gasket? It goes under this piece:
Got it!
What a great start to the morning!
Interesting how that internal gizmo does not show on the vid for rebuilding the gas cap.
Thank you very much.
now maybe the gas cap mounting ring will finally come loose from the gas tank opening...
z
11Back to top Go down   bit inside gas cap nose -- 1990 K1 Empty Re: bit inside gas cap nose -- 1990 K1 Sat Feb 22, 2020 3:38 pm
A word of advice: Don't take Chris Harris videos as gospel. (He's the guy who did that gas cap video.) It's great that he does those and he knows a lot about Ks but that's just the opinion of one mechanic.  For example, his advice to pack all of the gas cap parts with petroleum jelly seems very silly to me and is not necessary.
That gas cap mounting ring will come loose form the tank. Sometimes it just needs a little persuasion.
When you put the gas cap back on put some anti-seize on the screw threads and don't he-man tighten them.
12Back to top Go down   bit inside gas cap nose -- 1990 K1 Empty Re: bit inside gas cap nose -- 1990 K1 Sun Feb 23, 2020 9:00 pm
bldrhouse
bldrhouse
duck wrote:A word of advice: Don't take Chris Harris videos as gospel. (He's the guy who did that gas cap video.) It's great that he does those and he knows a lot about Ks but that's just the opinion of one mechanic.  For example, his advice to pack all of the gas cap parts with petroleum jelly seems very silly to me and is not necessary.
Duck,
thanks for that; I get it and the assembly finally came off with lots of silicone spray and a bit of gentle leverage.  foul and now cleaned.
yeah, all that petroleum jelly seems a bit much.
z
13Back to top Go down   bit inside gas cap nose -- 1990 K1 Empty Re: bit inside gas cap nose -- 1990 K1 Tue Mar 03, 2020 2:11 pm
Ash
Ash
Don't mean to hijack this thread, but didn't think my question needed it's own thread ;-)
My current tank leaks gas out the lid when I top it up and take a little bend or brake a bit aggressively right after. My lid is the one with the key and the push button.
Should I replace the seals for this cap or look to change to the "newer" cap with only the key?
EDIT: Woah the whole thing is a bit pricey BMW-K-100-LT-RT-RS-16111453012, so would rather rebuild the seals only..
Cheers,
Ash
1984 K100 RS
14Back to top Go down   bit inside gas cap nose -- 1990 K1 Empty Re: bit inside gas cap nose -- 1990 K1 Tue Mar 03, 2020 3:27 pm
Be patient second hand later caps do come up. After being quoted $180.00 Au by a BMW wrecker in Victoria, I picked up a really good one off Gumtree for $80.00 Au. Keep checking Ebay and whatever your equivalent of Gumtree/Craigs List is.
Regards Martin
