1Back to top Go down   Thermostat seal Empty Thermostat seal on Fri Mar 13, 2020 8:30 am
Not the o-ring under the cap, but the rubber u-channel seal around the thermostat itself. Has anyone found a substitute? I refuse to spend £36 to find out if this RT engine runs.
'83 K100 upgraded to K100RS spec, '87 K100RT
'78 Moto Guzzi 850-T3, '79 Moto Guzzi 850-T3 California,'93 Moto Guzzi 1100ie California
2Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Fri Mar 13, 2020 10:47 am
If you just want to start it up to see if it runs and don't plan on running it for an extended period then I think you'd be OK without a thermostat.
3Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Fri Mar 13, 2020 10:55 am
That's what I'm thinking, Duck. That, or temporarily gluing it in with Threebond. If it runs I'm still going to need a new seal though.
4Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Fri Mar 13, 2020 11:14 am
@Dai wrote:. . . temporarily gluing it in with Threebond . . .
It might be worth a try to meet the challenge of replacing a damaged thermostat gasket by applying a bead of Permatex Black Ultra—or its equivalent—to both sides and the edge of the thermostat's flange, letting it cure fully before assembly then assembling and considering it a permanent solution. Smile
Surely, a Brick motorradfahrer somewhere has done that by now and will come forward with a testimonial.
1995 K75 73,000 miles
Thermostat seal Usa-lo10
5Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Fri Mar 13, 2020 11:42 am
I was playing with a used radiator a few months ago and was thinking that if you put a normal O-ring behind it then that might work.  If a little coolant seeps past it then it probably wouldn't be the end of the world.
6Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Fri Mar 13, 2020 2:44 pm
@duck wrote:I was playing with a used radiator a few months ago and was thinking that if you put a normal O-ring behind it then that might work.  If a little coolant seeps past it then it probably wouldn't be the end of the world.
+1 That is the solution I would probably go with.
7Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Fri Mar 13, 2020 6:42 pm
tridon do a seal for that thermostat
ttg26 is the part number
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OThermostat seal Au-log10
8Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Fri Mar 13, 2020 6:50 pm
@charlie99 wrote:tridon do a seal for that thermostat  ttg26 is the part number
Tridon ttg26
9Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Fri Mar 13, 2020 6:51 pm
I glued it in with a good dollop of Threebond in the end. I figured that as cylinder heads get a lot hotter than coolant, the Threebond should be reasonably leakproof.
Charlie: that's got my attention. Thank you.
10Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Fri Mar 13, 2020 7:00 pm
Tridon ttg26
thanks Laitch
couldn't post a pic that I had , seems the widget for the file upload  has stopped working in the last couple of days  for me
11Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Sat Mar 14, 2020 5:10 am
Hokee... I've asked if they'll ship me half-a-dozen and how much.
12Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Mon Mar 16, 2020 1:54 pm
No luck. They don't export overseas.
Thank you for your email. Tridon Australia is an independently owned Australian company. We only distribute Tridon products throughout Australia and New Zealand. We do not have any links to the Tridon Brand or companies in other areas of the world, therefore unfortunately I cannot help you with your request. Toledo export clamps are available to be exported (there would be a minimum quantity & order value on these products).
Thank you & Regards Tridon Sales/Customer Service
13Back to top Go down   Thermostat seal Empty Thermostat seal on Mon Mar 16, 2020 3:34 pm
redrockmania
redrockmania
Dai - Looking on eBay I note a number of sellers offering the Tridon thermostat seal refer to the seal being suitable for several different Toyota Landcruiser engines, a VW Beete engine and a 1500 VW Kharman Ghia. This could provide you with suitable alternatives to the Tridon seal. Hope this helps.
14Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Mon Mar 16, 2020 4:29 pm
Dai on Ebay they are shown as fitting heaps of different vehicles. Mazda MX5 1.8, Mazda 2 1.5,Daewoo Kalos 1.5, Toyota Spacia 2.0, Toyota Cressida 2.0, Diahatsu Rocky 2.0 are just a few. If none of these are suitable go to OZ Ebay and type in Tridon ttg26 and it will give you more vehicle fitment choices.
15Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Tue Mar 17, 2020 6:05 am
As it happens, Bill (Indian036) is on the case. Very Happy If all goes well, I'll have a handful to distribute around the Eccentrics and the UK at cost.
16Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Tue Mar 17, 2020 6:14 am
In order to avoid needing one it's best not to fiddle with the thermostat in the first place.
"If it ain't broke, don't fix it."
17Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Tue Mar 17, 2020 10:16 am
Normally - yes. In this case I had a leaky rad with a thermostat and a non-leaky rad without a thermostat.
18Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Tue Mar 17, 2020 11:53 pm
@Dai wrote:As it happens, Bill (Indian036) is on the case. Very Happy If all goes well, I'll have a handful to distribute around the Eccentrics and the UK at cost.
good onya Bill
19Back to top Go down   Thermostat seal Empty Re: Thermostat seal on Wed Mar 18, 2020 5:47 pm
chris846
chris846
Rubber u-shaped edging seal (search 'rubber u seal' on oohbay, costs about five pence a kilometer) cut and stick the ends together with...something? Should survive in hot coolant.
Or spend a while on the interweb checking out the diameters of other manufacturers thermostat seals (very boring option)
The Longest Lunch
