peterbmw
peterbmw
BMW K75/K100/K1/K1100/K1200LT/K1200RS/K1300S spares and bikes
Having a clean out….
Pick up or post anywhere in Australia.
See separate lists below.
BMW K75RT K100RS K100RT K100LT spares:-
Gearbox $150
Gearbox indicator switch S/H $80 New $130
Alternator $90
Fuel tank 1983 to early 1985 (fuel sensor hole on LH side) $190 primed ready to paint.
Front wheel suit K100RS 16V 3.5 X 17", wider than std front wheel $290
Steering damper $90
Alternator $90
Starter Motor $90
Exhaust $50
Fork sliders
Centre stand excellent cond $120
Centre stand fair cond $60
Heated grips $90
Handlebar riser set $60
Frame with compliance 1985 K100RT straight $50
Crash bars suit K75 ,std chrome, with all mounts $220 set
Brake calipers $50 ea
Rear wheel $50
Upper fairing RT and RS $100 ea
Battery covers from $20 ea
Headlight $40
Dual seat, Dark blue (late model) no tears $90
Ducktail $80
Glove boxes $30 ea
Lower fairing lining panels $30 ea
Front guard $90
Fairing brackets
Fairing linings (cheap)
Panniers from $60ea
New set touring panniers with keys $400
Pannier frames $20 ea
Radiator $50
Foot pegs from $30ea
Foot mounts from $80
Radio cassette BMW OEM $190
Wiring harness $100
Relays from $20 ea
Coils $40 ea
Front axle $40
Gear lever $50
Radiator surround $70
Handle bars, RS and RT $70 ea
LH handle bar switch block early model connector $90
Brake and clutch levers $30 ea
Instrument bracket and metal rear cover
Coolant tank $20
Many more parts available
K1
Black/yellow seat fair cond. $90
K1 complete bike, Blue/Yellow, 50,000kms $9k
K1100RS K1100LT spares:-
Complete K1100LT bike. $2,000
Other spares available:-
ABS 2 ABS modulator $190
Late model tank $250
Instruments all working $190
Crash bar set, Standard chrome, with all mounts $220
Gearbox complete for spares, $90, has issue with 2nd and 3rd
Gearbox ind switch S/H $80 New $130
Final drive for parts only $90 (damaged housing where final drive shaft connects to final drive)
Frame with compliance 1993 and 1994 K1100LT $90 ea
Brake calipers $80 ea
Fork sliders
Rear wheel $50
Upper fairing LT and RS $100 ea
Lower fairing panels $60 ea
Radiator surround $50
Headlight $40
Ducktail $80
Glove boxes $30 ea
Front guard $90
Fairing brackets
Panniers from $60 ea
Radiator $50
Foot pegs from $30 ea
Foot mounts from $70
Wiring harness $100
Relays from $20 ea
Coils $40 ea
Front axle $40
Gear lever $40
LT handle bars $60
LT handle bars new $90
Exhaust OEM $120
Exhaust non OEM $70
Centre stand $80
Coolant tank $20
More parts available
K1200LT
GPS As new OEM Full kit, main unit, display, wiring, books etc $120
Windscreen motor $70
K1200RS
RH touring pannier with key good cond. Small repair $120
Upper triple clamp $80
Foot mounts $50
Lower spoiler $40
Few other bits
K1300S, 2011 model, red, Only 36,000kms, excellent motor/gear box/final drive, damaged front wheel and forks. All other parts available.
All items plus post or can pick up Central Coast NSW
Peter
Mb 0409 765527
Can you put a pic of the K1 so I can dream about owning one
Matt
1986 K100 RS Motorsport
#### K100 RS Project
2011 R1200 GS
tborosak
tborosak
hey mate you wouldn't possibly have a hub cap for the rear wheel do you?
BMW k100 RS 1985 (Cafe Racer)
TOM Wink
https://www.instagram.com/tomborosak/
