1Back to top Go down   New here 85 k100 brick Empty New here 85 k100 brick Thu Mar 26, 2020 12:51 pm
Antbmw
Antbmw
New here looking for some tips to restore my 85 k100. 27,000 miles but needs a tune
2Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Thu Mar 26, 2020 12:55 pm
3Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Thu Mar 26, 2020 12:57 pm
Welcome!  27,000 miles?  Still needs breaking in!  Check all the rubber stuff for cracks and stiffening.  Get a can of Deoxit and go through every switch and electrical connection, especially the grounds.  Change the brake fluid!
4Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Thu Mar 26, 2020 2:15 pm
Last year I got an 83 one with 29,000 miles. Lots of rubbers replaced, needed full brakes job, services, coolant expansion pipe, tyres, still needs a few things one being that the water pump will give out and eventually the rear main seal too. But a lovely bike to ride too and very happy with it.
5Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Thu Mar 26, 2020 2:26 pm
I've had plenty of Ks that never had WP or main seal issues.  Yes, then CAN fail and need replacing, but not always.
6Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Thu Mar 26, 2020 2:35 pm
St Augustine FL... Mmmm... I love that place! Been there three times.
New here 85 k100 brick 177912
7Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 4:12 am
Welcome Antbmw Smile
New here 85 k100 brick Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
8Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 7:09 am
duck wrote:I've had plenty of Ks that never had WP or main seal issues.  Yes, then CAN fail and need replacing, but not always.
I bought a K100RT back in 2013 at 36,000 miles. A year later it needed the WP [original] done and then another year later at 78k miles the rear main seal [also original] and slipped in clutch etc too.. I have no complaint but realise buy an old K you may need to do them. I still have it.
9Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 7:33 am
Antbmw
Antbmw
Duck,
Good morning my main issue is consist running. I feel like the return fuel line is clogged at the tank. I’ll get the engine running which is sometimes hard with out using the starter button to get it warmed up. But once it’s warmed up I can’t just turn the throttle I have to do it really slow to build rpms. Then when I run to long it just seems like all my work goes to a waste. Must be back pressure on the return line. I think I’m going to run a return line straight to the top of the tank temporarily just to see if that’s my problem. After replacing everything in the fuel system I thought I’d be there by now. Any suggestions are always welcome
10Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 8:55 am
mike d
Have read through the fault finding guide (it's on the Portal Page).
Have you measured the water temperature sensor when cold.
Mike
11Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 10:17 am
Antbmw
Antbmw
No I haven’t the fan kicks on but it does feel hott
12Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 10:35 am
A bad engine temperature sensor will make the fuel injection run rich and can flood the engine.  It's an easy check, but a bitch to replace.
Return line back pressure can be caused by the check valve at the spigot where the return line enters the tank.  They have been know to stick closed.
Have you replaced the fuel filter.  NAPA 3032 is the one to get.
You may want to run some fuel system cleaner through to clean out any varnish that may have formed in the injectors.  Techron by Chevron is good stuff.  About 6-8 ounces in 5 gallons of fuel is a good mix.  If the bike isn't rideable, I will start it up and run it until the temperature gauge starts to move.  If no gauge, 4-5 minutes is about right.  I'll go out in the garage and do this a couple times a day for a couple weeks.  The idea is to let the cleaner soak for a while and then flush it out while the injectors are being pulsed.  I've only had one bike that didn't respond favorably to this regimen.  In that case it may be necessary to remove the injector to have it cleaned.
Another source of problems is the crankcase breather hose A.K.A. the Z tube.  It's behind the throttle position switch (TPS), and is a very common source of problems when it cracks and allows an air leak in the air box.  It's not expensive and is the first thing I check and replace when I get a new bike.
13Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 10:48 am
mike d
Hi,
Having written this once it seemed to get lost when I posted it:
The Water temperature sensor has two functions:
1. An input to the EFI (pin 10). If this is faulty, it will send a wrong signal to the EFI, and usually results in rough running. If you measure between Pin 10 and earth on the EFI connector (NOT THE EFI MODLE), then at 20C it should be in the order of 2.5k ohm, and at 80C around 300 ohm. If you get a low resistance when cold it will over fuel, leading to it being difficult to start the bike
2. The other side of it is connected to the temperature switching unit via a connector.
The TSU is located with all the other relays. It controls the fan and the over temperature warning light. The fan is activated first, then at a higher temperature, the light is illuminated. If the bike is running at this stage, then it will still be able to run. If however, the engine is stopped, then with temperature light illuminated, the bike will not be able to be started. It will remain in this state until the engine cools down sufficiently for the temperature light to be switched off.
Mike
14Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 11:07 am
volador
volador
Welcome
work around for petrol tank check valve removal by Sidecar Paul
[url=http://www.kforum-tech.com/how-to/Modification for early gas tank.htm]Modification for early gas tank[/url]
if you get a 404
-start here http://www.kforum-tech.com/
-under "How-to from the forum"
-"Modification for early gas tank"
15Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 12:45 pm
Antbmw
Antbmw
Thank you all. Yeah new fuel filter, injectors,z pipe, pressure regulator, and fuel pump. I’ll check into the temp stuff. I completely removed in cleaned the tank but the return fuel line still seemed to have a blockage afterwards
16Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 1:05 pm
With just 2 gallons of fuel in the tank can you see fuel returning when the engine is running?
There should be a pretty obvious flow in the tank forward of the filler.
17Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 1:11 pm
volador
volador
fuel pressure regulator my be malfunctioning- stuck closed
18Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 2:02 pm
Antbmw wrote:Thank you all. Yeah new fuel filter, injectors,z pipe, pressure regulator, and fuel pump. I’ll check into the temp stuff. I completely removed in cleaned the tank but the return fuel line still seemed to have a blockage afterwards
You don't mention the vacuum pipes and the vacuum caps. They all need to be good.
As yours is 85 you may have a fuel pressure sensor as ell as a fuel pressure regulator, located beside the fuel pressure regulator.
It doesn't do anything and you don't need it, but it does have a vacuum line that goes around the front of the throttle bodies. Remove the vacuum line and replace it using a vacuum cap same as the others on the throttle body spigot.
At the rear end of the throttle bodies near the Z pipe there is the vacuum line to the fuel pressure regulator....got to make sure that's good and not cracked.
19Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 2:02 pm
Smooth idle? A basic thing, not related to fuelling obviously, but have you had a squiz at the short, elbow-shaped engine oil breather hose that runs up into the the left rear corner of the airbox? Squeeze it, looks for cracks. A test of this hose is to let the engine idle (trusting that it's smooth initially) then slowly unscrew the engine oil filler cap and watch the idle change. If it changes from smooth to rough the hose is in good nick. If it is cracked and you're slowly turning the throttle and experiencing misfire or stumble, perhaps it's having a hard time simply because this hose is leaking excess air. Worth a quick look.
OEM part number 11 15 1 460 480
How we spend our days is, of course, how we spend our lives. - Annie Dillard, author - born 30 Apr 1945
20Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Tue Mar 31, 2020 2:38 pm
Antbmw
Antbmw
Z pipe is new. Anyone of you guys live near st. Augustine fl.
21Back to top Go down   New here 85 k100 brick Empty 85 Tue Mar 31, 2020 5:36 pm
daveyson
daveyson
Maybe a blockage in exhaust or air inlet, or both, especially if it hadn't been started in years.
 ~120,000 km
22Back to top Go down   New here 85 k100 brick Empty Re: New here 85 k100 brick Wed Apr 01, 2020 2:31 am
volador
volador
Antbmw wrote:Z pipe is new. Anyone of you guys live near st. Augustine fl.
I'm in Orlando. Just finished 21 day quarantine all clear of the K-19
pm your address I can come over whenever
Last edited by volador on Wed Apr 01, 2020 7:55 am; edited 1 time in total (Reason for editing : spelling error)
