svenok
svenok
Just trying to put everything back together after an extensive hibernation, and I don't know what protection there is for the ABS/ECU under the seat.
The battery bracket has screw holes for the ECU and the ABS. The ABS has a box surrounding it but the ECU is not?
Also there doesn't appear to be any rubber mountings for vibration dampening or water ingress if the bike is left on the side stand.
Am I missing parts?
K100RS 12/90 WB1052309M0200614
Bonzo
Bonzo
svenok wrote:Just trying to put everything back together after an extensive hibernation, and I don't know what protection there is for the ABS/ECU under the seat.
Am I missing parts?
Nope, you appear to have everything that it came with  Whats under the seat............K100 RS 1990 16V 112350
1990 K100RS 4V (VIN# 6406682)
2017 R1200RS SE Sport
svenok
svenok
Am I missing parts?
Ok thanks for the reply, I've place a slither of insertion rubber under the ECU just because.
svenok wrote:I've place a slither of insertion rubber under the ECU just because.
Modifying without reason can lead to repercussions from the Law of Unintended Consequences. Smile
The Motronic unit sitting on the battery has a rubber mount at the front and a screw in a rubber mount at the rear, if its the same as on the K1100 and as such is insulated from vibration.
It also0 therefore has clear airflow around it, meaning it has cooling.
