Hi,
I'm assembling the drivetrain of my bike. I thoroughly cleaned the rear swingarm bearings of dirt and old grease. Is there a correct or incorrect way of repacking the bearing with grease before reinstalling the swingarm? I'm thinking that I take a grease gun along with some general purpose lithium grease and inject grease into the cup. When I insert the swingarm pivot, it should press the grease into the rollers of the bearing. Is this correct?
2011 Moto Guzzi V7 Racer
japuentes
japuentes
Hi there.
That´s what I did, the grease retainer behind the bearing will force the grease into the rollers.
Best regardss
hi rob .....whenever there is a conical bearing concerned it is always best to "pack" the bearing with grease whilst out of the cup .....an old technique but a good and proven method through the test of time.
what "packing" means is to use your palm of you hand to force the grease into the cage structure surrounding the rollers ...i dont have a cleaner way of doing it ....sorry ...
start out the outside and load grease into the roller cage ....then again at the inner race part .....smothering more grease in the actuall roller in the centre of the bearing face with the palm of your hand until it pushes more grease out of either end ...the intention is to remove any air gaps where grease has not filled ..
once "loaded" as to say it ....a wipe off of excess grease and insert it into the outer cup ....trust me ....it will stay there for ages ...and as the "load" "takes up" you will have nice clean grease in all the right places .
BIG D
BIG D
Cool
Like Charlie says rob, thats how I did mine it gets in all the right places.
BIG D
Heh Charlie,
Are you saying that the swingarm bearings can be removed from the swingarm for packing? From reading Clymers, I was under the impression that I needed a special BMW extractor tool to get the bearings out of the swingarm. In the process of cleaning them, I have pulled up on the inner race slightly to separate the parts and allow more cleaning fluid into the space. But I've never had the bearing apart; they don't seem to separate easily as did the taper roller bearings on the steering head of my friend's Norton Commando, for example.
I'll try pulling a bit harder but, barring the ability to extract these suckers, will my process work? I'd love to use the proper method but if it requires me to use a bearing puller to do it, I'll pass.
hey rob the sites say that its a conical bearing
http://www.realoem.com/bmw/showparts.do?model=0504&mospid=51753&btnr=33_0641&hg=33&fg=20
between you and me i think these bearings are pushed into the rear wheel fork (swingarm) with some force ...Or more properly are siezed in there good ...to my way of thinking they should extract relativly easily ...unless they have worn an inner ridge on the bearing cup (quite likely ) worst case i could think of bob ...is to stuff the outer roller cup with lots of goo (palm pressed ) but really if they are worn like that ...might be time for a change huh ??!!! dont forget they only move about < 30 degrees or so durring operation and the tightening tecnique is prone to pushing then in harder..... puller ??? wow whats wrong with a long brass drift to push them out from the other side ???? cuppla taps ....bingo
10 cents from an old fella
Hi Charlie,
The bearings are conical but have a dust cap (two actually, one is easily removed, the other not so). They won't extract easily but maybe I haven't used enough force for fear of breaking something.
I agree that there is a certain amount of preload that is imparted by the adjustable pivot. The bearings don't seem to be worn (they are not notchy) and I don't want to replace them if at all possible because (1) the bearing is doscontinued from the manufacturer and (2) the cost is outrageous at $70 per bearing. At this price, I don't want to accidently break a bearing.
The bearings are captured in a sealed cup in the swingarm so it is not possible to inject grease from behind or use a brass drift as you suggest. I saw a Youtube video on packing a roller bearing but I can't extract mine to do that type of packing.
I think I'm going to just pack grease in the cup and squish it into the bearing using the pivot as a piston and hope for the best.
UPDATE: Well, it went pretty well. Grease got squeezed throughout the bearing and poped out the dust shield. It was easy.
Last edited by robmack on Tue Jul 12, 2011 4:27 pm; edited 1 time in total (Reason for editing : Update with results of putting grease in the bearing.)
Hi Rob!
The reason for the stubborn behaviour of your bearing is: in the outer race it`s two grooves,
one for the inner dust seal and the other one is for the roller cage.
The bearing can be dismantled...patience, strong glasses and the needle pointed instrument
you did borrow from your dentist last time you did visit him.
Oldgoat
Oldgoat
Hey Rob,
Can you take pic if you get it apart...
Thanks Buddy,
OG
japuentes
japuentes
Hi there, yes the bearings can be dismantled, check the Haynes, they use an slide-hammer with an internally-expanding attachment. I didn´t do it by robmack´s same reasons. The bearings and the old grease feels and looks good, by pressing the new grease the old one will flow out and you´ll be ready for another 20 more years.
Best regards
JAP
I just want to make a point about greasing bearings.
I remember an old rule (learned almost 40 years ago) when I was studying industrial mechanics. This method is general and work for the majority of applications.
For a bearing with a single row of balls, the quantity of grease should be approximately equivalent to the volume of one ball. This was the same for roller bearings.
The type and quantity of grease is a precise science and speed, pressure (or preload) as well as working temperature have to be considered.
When you buy a new bearing, it is already pre-greased from the manufacture and you can notice that it's never packed.
This Web site gives you an idea.
With this other site you will be able to calculate the interval between re-greasing.
I know, this is dry theory (Laughing) but this is the proper way to lubricate a bearing.
CF
1986 k75, 1985 K100rt, 1985 K100rt/EML sidecar.
hi rob ....yes i saw that bearing removed in one of the service manuals also ....and now thinking about it ...it was blind to the back of the pivot .
good work on packing mate ....hope you get lots of k's from her
BIG D
BIG D
Cool
Two good sources of info there CF, we learn as we go along cheers.
BIG D
you can get the cone and rollers out easily, just insert large lever through centre of bearing and lever in several different directions and pop it will come out.
WARNINGS be sure to catch all the rollers as they canjump out quickly and take care with the fragile plastic roller cage.
clean all parts including seal and dust seal and put enough grease on it to hold the bits in place and push it back together, it will sort of click as it goes in.
leave the cup race in the swingingarm and clean and grease it in situ. the grease i use is either shell optimol or a moly grease as both are fairly waterproof.
if you need to get the cup race out run a bead of weld around the inside of the cup race and let it cool then a quick shake will see it fall out.
you only take it out if it is badly worn and needs replcing so the weld won't hurt well unless you touch it with your finger.
Oldgoat
Oldgoat
Great info guys and thanks for the excellent link Bert! I'm thinking I will pull mine when I do the FD seal later this month.
OG
16Back to top Go down    Swingarm Bearing on Thu Sep 20, 2012 4:16 am
JonnyE
Here's how I dismantled my swingarm bearings. To remove the bearings from the swingarm, I used a slide hammer with the correct sized collet - the bearings came out easily. There are two seals on each bearing. The outer seal may come off by prising the edges with your fingernails. One of mine was stuck firm so I used one of those tiny flat bladed metal screwdrivers used in electrical jobs - gently pry round the outer edge. Once the outer seal is off, you can clearly see the inner seal underneath. Using that same tiny screwdriver, push the blade quite firmly between the inner seal's outer edge and the bearing and gently pry as you work your way around the outer edge of the seal. It should come off pretty easily. Now that both seals are off, you can remove the bearing race. Turn the bearing over and, using your thumbs, push on the bearing whilst pulling on the race with your fingers - work round the bearing and the race should come off.
K100LT 1987
To remove a bearing installed in a blind hole, I use Hydraulic pressure.
Get a metal bar the same diameter of the inside diam. of the bearing. (5" or 6" long)
Generously pack the center hole of the bearing with grease.
Insert your your metal bar into the bearing.
Get a heavy hammer and 'whack' the metal bar.
The pressure applied to the grease will push the bearing out.
This solution is used when you want to replace the bearing as sometimes, the grease pressure will pop the seal out and you won't be able to re-use it.
CF
@Crazy Frog wrote: the grease pressure will pop the seal out and you won't be able to re-use it.
And the seals isn`t available as a single part.......
The bearing sold these days look a bit other than the old ones......it seems like it can`t be dismantled so easy as the old ones?
After cleaning out the swingarm bearings I need to repack them with grease. I have a tub of Penrite Molygrease EP 3%. Is this ok to use?
I've got the covers off them but can't remove the bearing so I'll pack as much in from the outside as I can. There doesn't appear to be any covers on the inside. Is this a problem?
1988 K100RT     VIN No.  0094680
     Fuel:  95 Octane
Number one place it somewhere that the rollers don't disappear into the black hole.
I put a large screwdriver into the centre and a sharp jerk will dislodge the cone with rollers. The plastic cage will probably be in bits or at least split but you can use it again clean grease and its easy to put back together just a push with the thumb relocates the cone. That penrite is what I use on the swingarm bearings.
To get the cups out some heat to about 150°C and a sharp tap against a block will do the job, they just fall out. Cut a piece of colourbond steel for the inside to seal the dirt out.
Thanks Rick. I gave it a go from your suggestion further back but I'll give it another go and persevere a bit more.
     Fuel:  95 Octane
alby just fills the hole in the centre of the bearing with grease ...then placing the bearing pivot thingy into to bearing ...pushes the grease through the bearing from the rear
after removing the pivot pin you can see the grease permeating through the bearing from the rear ...on the occasion of the last time I did it  it had filled the bearing almost completely pushing the old grease towards the front ...for easy removal
hey !  it works for me ...a great idea. and thanks alby
The hole in the centre of the bearing just goes straight thru to the swingarm housing. You can see thru from one bearing to the other. I've not been able to work out what these "cups" are that Rick mentions. It looks like possibly I don't have cups.
     Fuel:  95 Octane
The bearing cup is what I meant, the outer piece of the bearing mate.
rawdonball
rawdonball
Hey Captain
It sounds to me like you are missing the disc (thin metal plate) which fits in the bore of the swing arm prior to swing arm bearing installation. If you look through the opening where the rubber bellows attaches to the swing arm, you should see a shiny disc surface - bit like a core plug / welsh plug in appearance. If yours has been removed in the past by someone wanting to drive out the bearing cup by accessing the shoulder from within the swing arm, then you will have nothing to deflect the grease back through the bearing when using the method outlined by Charles99
Hi Rawdonball.  I thought that was the case. Anyway, I've cleaned them right out and they seem to run smoothly when seated. I think I'll replace them sometime soon anyway... 32203??  but will just repack them in place this time round.
I can see now how all this goes together. The grease retainer (optional) sits in behind the bearing and closes the back of the bearing off. I'll install retainers when I replace the bearing down the track.
Thanks everyone for the info
     Fuel:  95 Octane
I have to do the bearings on my bike.  Can someone point out where this "disc" you're talking about is located.  I have never seen it in any of my bikes.
Last edited by Point-Seven-five on Sat Jan 14, 2017 11:58 am; edited 1 time in total (Reason for editing : Speling eruhr)
1994 K75S
1992 K100RS
As mentioned, it's a thin metal disc that blanks off the hole behind the bearing. I think it was only fitted to early machines as I once bought a later swing arm that didn't have these discs installed, so that's probably why your '90s bikes don't have them.
So it looks like heat is the way to get the bearings out.
1994 K75S
1992 K100RS
TIV
TIV
I recently bought a new set of swing arm bearings. Inge, you are right, the inner and outer races are one unit and pre-packet with grease from the manufacturer. Seems to me that they would be difficult to dismantle without damaging.
One other thing. There are no grease retainers / cups behind the bearings in my swingarm. I did not see any signs of them having been there.
1936 Harley Davidsson 750 (sold), 1964 BMW R69S (sold), 1973 Suzuki RM400 (sold), 1972 Triumph Bonneville (sold), 1971 BSA Thunderbolt (sold), 1972 BSA Lightning (sold), 1977 Yamaha XS650 (sold), 1971, BMW R75/5 (sold), 1973 BMW R75/6 (sold), 1984 BMW R100RT 1992 Yamaha FJ1200 ABS (sold), 1990 Harley Davidson Electra Glide (sold)
1990 BMW K75RT Ex-Police (owned now)
2004 BMW R1150RT iABS (owned now)
Cheers TIV
