1Back to top Go down   K1100 power plant g/box into k100 Empty K1100 power plant g/box into k100 Mon Aug 29, 2011 9:05 pm
colesy
Hi all,
does a K1100 engine g/box combination physically fit into a k100 frame?
Assume I have the 1100 ECU wiring injectors etc
I gather the rear shock will need to be longer anything else I need to worry about
Dave?
Yep it will all go in. You need the whole lot air box and all.
You do need a shockie that is 380mm eye to eye. but I do know of some who still run a K100 shock but it makes the rear 25mm lower.
Did you score that one from albury.
Avenger GT
Avenger GT
You will also need the paralever swing arm and final drive if you use the K1100 gear box.
4Back to top Go down   K1100 power plant g/box into k100 Empty Re: K1100 power plant g/box into k100 Mon Aug 29, 2011 10:20 pm
colesy
Hi KFreak,
yeah, picked it up from Albury way. I figured that with 200k + k's on the K that this was probably a good deal. It's been in a garage for a long time - another boys project that didn't happen. Came with injctors throttle bodies etc but don't have the air box though!
Dave
5Back to top Go down   K1100 power plant g/box into k100 Empty Re: K1100 power plant g/box into k100 Mon Aug 29, 2011 10:27 pm
There is an airbox going on ebay at the moment http://www.ebay.com.au/itm/1997-BMW-K1100-Air-filter-box-/320748902939?pt=AU_Motorcycle_Parts_Accessories&hash=item4aae1fda1b
Are you intending to come to Araluen for the get together in Oct, its near Canberra
If you can't get a decent eBay price on an airbox for a K1100 in OZ or the US look a little deeper in Germany as there are a whole heap of them there as cheap as chips...postage isn't as bad via Deutsche Post as it is from Royal Mail via the UK. They are a rip!
That Wodonga 16V deal had the swingarm and final drive too if that's the one you got. I was pondering it too. What a score!
nice one colesy ....
