1Back to top Go down   Wanted k100 drive box and shaft Empty Wanted k100 drive box and shaft on Wed Sep 07, 2011 1:42 pm
martindavid
Does anyone have a k100rs 1984 drive box and shaft for sale or something thay would be suitable preferably to give a higher gear ratio. Mine needs all new bearings and the uj is shot. Seems quite expensive to replace all the worn parts unless anyone knows better I would be pleased of some advice
thanks
2Back to top Go down   Wanted k100 drive box and shaft Empty Re: Wanted k100 drive box and shaft on Wed Sep 07, 2011 5:11 pm
By 'drive box' do you mean the gearbox or do you mean the final drive?
I'm going to assume final drive since gear ratios are mentioned. The RS model already has the higher or taller (2.81) of the two ratios compared to the RT/LT (3.0). There are many listed on eBay in Europe and the US. Your driveshaft will be an early, 16 spline version (20 spline was mid-'86 on) and there are a few of those listed there as well. The expense is relative but if you have a good squiz you'll find something.
