1Back to top Go down   Fuel pumps - Bosch - 0580464070 Empty Fuel pumps - Bosch - 0580464070 on Tue Oct 11, 2011 8:46 am
Jhepburn
Jhepburn
While hunting up more details on substitute fuel pumps (I'm very cautious about fitting the wrong one, but don't want to pay full price - who would?) I came across these two PDFs from Bosch in Australia.
The catalogue: http://www.bosch.com.au/content/language1/downloads/BOSCH_Fuel_Pump_WEB.pdf
Says this: "There are a total of 7 universal electric fuel pumps available from Bosch, to replace the previous range of 72 electric fuel pumps." Which is promising, to say the least.
Then specs sheet: http://www.bosch.com.au/content/language1/downloads/fuelpumps.pdf
Number 0 580 464 070 has these specs: 52mm external diameter, 8mm outlet pipe, 3bar pressure (43.5psi), 130L/hour, 175mm long, 12mm inlet connection.
That looks almost perfect for us - as used in BMW 3 and 5 series, Holden Commodores here in Aus (therefore easy to find!) and a whole stack of other cars.
Now: I've never pulled out a K fuel pump and I'm not sure how the pump handles fuel input, or the extra details like how long they are.
Anyone see a problem with this? Is it a perfect plug-in replacement?
2Back to top Go down   Fuel pumps - Bosch - 0580464070 Empty Re: Fuel pumps - Bosch - 0580464070 on Tue Oct 11, 2011 10:08 am
I bought a Fuel Miser brand pump for mine some time ago and it was a lot cheaper than a Bosch or the original. I can't remember the part No but the specs would tell if it was right. There a lot of pumps out there that work well with them. I used the pump from an EA falcon because I couldn't afford to buy one and it worked fine. I also fitted a ford one to a friends K75 about a year ago and no problems.
3Back to top Go down   Fuel pumps - Bosch - 0580464070 Empty Re: Fuel pumps - Bosch - 0580464070 on Tue Oct 11, 2011 10:12 am
nice ......2 things ours has a ring around it that holds it height wise in the rubber mount .....maybe a clamp around the rubber mount would solve this
the pickup is 12 mm ....not really an issue ...but you would still use our filter in the absence of another
the current and flow + termination all looks ok jh
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OFuel pumps - Bosch - 0580464070 Au-log10
4Back to top Go down   Fuel pumps - Bosch - 0580464070 Empty Re: Fuel pumps - Bosch - 0580464070 on Tue Oct 11, 2011 2:10 pm
Roejen
I saved my old original one and gutted it. I then got a small peace of PVC to put around the new one and slide it into the old one.
5Back to top Go down   Fuel pumps - Bosch - 0580464070 Empty Re: Fuel pumps - Bosch - 0580464070 on Thu Nov 03, 2011 11:45 pm
K Freak wrote:I bought a Fuel Miser brand pump for mine some time ago and it was a lot cheaper than a Bosch or the original. I can't remember the part No but the specs would tell if it was right. There a lot of pumps out there that work well with them. I used the pump from an EA falcon because I couldn't afford to buy one and it worked fine. I also fitted a ford one to a friends K75 about a year ago and no problems.
I shagged one going to Araluen and a EA Ford Falcon multi point injection pump worked fine but as before I had to use a couple of zip ties to hold it into the rubber thingy and change the connectors to a spade type.
