1Back to top Go down   k100lt Centre stand Empty k100lt Centre stand on Thu Jan 19, 2012 4:52 am
col
col
Wanted centre stand k100lt
does any body in the land of oz have a centre stand they would like to part with
after lowering bike i have lost use of centre stand(arms to short bike to heavy) and would like to get another so i can cut up and reweld back together
1991 k100lt "the enterprise"
2Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Thu Jan 19, 2012 5:34 am
I might be able top help Col, I'm about to replace mine as it is too narrow, and it will become a spare. If you can give me about a week
I should get it done. Went thru Orange again yesterday, was a bit hot
on the road. (you better call me in a week, you already know how my memory is)
Bob.
3Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Thu Jan 19, 2012 5:37 am
not just yet col ....doing some cutting myself soonish ... good luck !!!
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%Ok100lt Centre stand Au-log10
4Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Thu Jan 19, 2012 5:59 am
col
col
bit rude rt second time thru and you didnt stop in and i am on holidays too
i give you a call next week to jog your memory
this is the second time you got the parts i want may be i need to come down and raid your shed
thanks col
5Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Thu Jan 19, 2012 6:21 am
I cut one for a friend, and it was not a simple operation.
Because the arms are not parallel, if you reduce their length, you have to extend the width of the stand too.
If you cut A, B will be reduced and C will have to be extended to compensate.
k100lt Centre stand Stand10
The stand will not retract where it should be against the muffler. If you don't modify the side stand, it will hook on the centre one.
When I cut the friend's one, she asked me to reduce it by 3/4". That's was way too much and I had to fit spacers under the gear box to compensate the height.
A simple 1/4" makes a BIG difference...
The alternative is to get a K1100 stand. They are a lot easier on your back. Again, the original side stand will not work properly with the K1100 centre one. You have to get both k1100 stands.
Here is the K1100 vs K100
k100lt Centre stand Centre10
CF
k100lt Centre stand Frog15k100lt Centre stand Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
6Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Thu Jan 19, 2012 6:53 am
That looks tricky, I think I might just apply some heat to get a bit more clearance and reinforce the joints again.
Some people just don't seem to sleep do they Crazy Frog must be the northern lights.
Regards
7Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Thu Jan 19, 2012 6:56 am
@RT wrote:Some people just don't seem to sleep do they Crazy Frog must be the northern lights.
Yes Northern light is brighter since they replace it by LEDs k100lt Centre stand 723598 k100lt Centre stand 723598
8Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Thu Jan 19, 2012 1:50 pm
walfish
walfish
Looks as the 1100 stand left peg is angled to create the clearance, or are my eyes pissed??
9Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Thu Jan 19, 2012 3:36 pm
WayneDW
WayneDW
Here is a somewhat unrelated question: I just took my center stand off my K75RT and found two springs on the floor afterwards. Hadn't as of yet figured out where exactly they go until I see them on those pics. Thanks for that!
But, my question is, that I notice the stand on the left has the "protectors" on the springs opposite each other. (one upside down from the other). But the stand on the right has them the same side up. I'm guessing the one on the left is correct? Right?
http://www.fossilapostles.com
10Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Thu Jan 19, 2012 6:00 pm
col
col
i will talk with my engineering mate as he will be doing the welding and he is lot smarter than me
this is what i love about this forum you put an idea out there and normally someone has tried it and they let you the pitfalls before you start
thanks cf saved me a lot of hassles i didnt think of
11Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Thu Jan 19, 2012 6:01 pm
You are correct Wayne.
The rubber are just there to keep the springs apart and avoid any chaffing.
12Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Mon Jan 23, 2012 7:22 am
Hey Col looks like you are in luck, the spare I have is like the one on the left in Berts photo's above, no sidestand or connector for the clutch lock or no spring lugs on the sidestand side.
It's yours if you want, and if it ever stops raining I might be able to
do another tour of duty up your way , or give me a bell and we can sort something out. (bike out of action just at the moment to get my stand widened).
13Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Mon Jan 23, 2012 3:19 pm
good luck rt and col , hope it works out ok
got to do something similar and the advice has been helpfull
14Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Mon Jan 23, 2012 9:53 pm
col
col
thanks rt i will call you and organise it
15Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Mon Feb 27, 2012 10:14 am
RT - did you change your side stand for the k1100?
I came across one in a breakers yard and I could do with making the change if it's easier on your back (old injury acting up!).
The k1100 side stand seemed to be a bit looser i.e. much more lateral or sideways movement as opossed to the normal swing arc. or is it that this particular one is very worn?
88KE
16Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Mon Feb 27, 2012 5:35 pm
Hi mate
no I ended up sending it off to a better home with Col, after I pulled mine off (the new sports demon tyre was too fat) I realised that at some stage it had collapsed and previous owner/s had welded it up
with a bit of a warp in it, so I had it heated and straightened. Once I tightened everything up, new springs and sleeves in the pivots it came
out pretty well. I used to have an almighty clang as it went up, telling me it was off the ground, now it even comes up to the rubber bumper
and misses the heat shield.
So no help I'm afraid.
17Back to top Go down   k100lt Centre stand Empty Re: k100lt Centre stand on Mon Feb 27, 2012 7:37 pm
Sounds like a good result RT. I know that clang sound too Very Happy
k100lt Centre stand Ir-log11 88....May contain nuts!k100lt Centre stand Ir-log11
