1Back to top Go down   Making her pretty. Empty Making her pretty. Sun Jan 15, 2012 6:52 pm
Norfolk_Boi
Norfolk_Boi
Here is my cracking 1984 K 100. I love this bike, although as you can see I'm not to keen on polish Embarassed .
Anyhow I decided to alter her a little:
Making her pretty. DSCN1617
Making her pretty. DSCN1618
She's now sporting a nice chrome headlight, polished alloy headlight brackets and will soon have a single seat with the seat rails chopped off. The numberplate and rear light will mounted on the side.
I would like to remove those clunky old clocks, but the starter and charging system doesn't work when they are removed? Any way past that do you know? I would also like to cut down that exhaust and have a 'turnout' at the end of the downpipes. I would like her louder, she's way to quiet, but not too loud.
This winter she'll be stripped, the frame will powder cotaed black and the bodywork/ tank sprayed gun metal grey. She'll look lovely Very Happy .
2Back to top Go down   Making her pretty. Empty Re: Making her pretty. Sun Jan 15, 2012 7:09 pm
g35corona
g35corona
Welcome aboard Norfolk_Boi. Sounds like a great project. I can't answer your question but I'm sure someone here can.
Bob
;BMW;
ex:1986 K100 RT Vin #0091835
2012 R1200 GS
3Back to top Go down   Making her pretty. Empty Re: Making her pretty. Mon Jan 16, 2012 6:01 am
pity the aussie "stayintune " is no longer made "boi" .... just what the doctor ordered ......there are a few others that sound nice as well ...motad (sp ) comes to mind ..."guest in the house" has one and its a bit "crisper" than the standard else get in touch with "caferacer" who has rolled his own .... http://k100rt.aforumfree.com/t2962-poor-mans-staintune-remus ....havent heard the remus yet
4Back to top Go down   Making her pretty. Empty Re: Making her pretty. Mon Jan 16, 2012 8:11 am
beanoldboy
beanoldboy
yes nice pony norfolk, im keen to see how this one turns out.
have you seen the cafe racer on utube with the straight through shotgun system ? it pops nicely .
N.
http://www.airware.com.au
5Back to top Go down   Making her pretty. Empty Re: Making her pretty. Mon Jan 16, 2012 8:45 am
Toto_jp
Remus nla Sad how about straight thru stainless pipe with a chrome turn out tip
K100 RS 1986
6Back to top Go down   Making her pretty. Empty Re: Making her pretty. Mon Jan 16, 2012 8:53 am
beanoldboy
beanoldboy
now im just puttin it out there , but how bout four tuned length headers straight through ? mayhaps a collection ring of some descript to keep them together at the noisy end . has any one seen these bikes with four separate systems?
7Back to top Go down   Making her pretty. Empty Re: Making her pretty. Mon Jan 16, 2012 11:42 am
Norfolk_Boi wrote:I would like to remove those clunky old clocks, but the starter and charging system doesn't work when they are removed? Any way past that do you know?
Changing the instruments is a subject in this rather long thread, you might get some other ideas, too.
8Back to top Go down   Making her pretty. Empty Re: Making her pretty. Mon Jan 16, 2012 1:46 pm
Norfolk_Boi
Norfolk_Boi
Cheers. I'll have a read through that sometime. Just watched that video with the K with the straight through pipes. Now that's LOUD Shocked .
I would like the ol' girl a little louder, but nowhere near that. I'll most likely leave it until winter to do stuff like that. Just want to concentrate on the single seat conversion for now, and maybe wider bars as the ones fitted are too narrow.
Making her pretty. DSCN1620
9Back to top Go down   Making her pretty. Empty Re: Making her pretty. Sat Jan 21, 2012 10:22 am
Norfolk_Boi
Norfolk_Boi
The problem with working full time and having no leccy in my garage, is that I can't really do bugger all during the week Rolling Eyes .
So here is the latest instalment:
Seat rails cut down as well as the seat.
Making her pretty. DSCN1631
Making her pretty. DSCN1627
Seat will be recovered over the weekend and the plastic guard will be cut down to where it bolts to the frame. Hoping to remove those horrible clocks and the ignition surround. The pillion footrests are coming off and being fitted on the front as the rubber is pretty worn on the front ones. I'm looking for a small metal box to fix to the right side footrest hanger, the numberplate will fix to the rear of that with the rear light above. I would like to place the fuel injection control unit, the power socket and ignition into that. I could also have the tool kit and lock too.
10Back to top Go down   Making her pretty. Empty Re: Making her pretty. Sat Jan 21, 2012 11:49 am
Norfolk_Boi wrote: I would like to place the fuel injection control unit, the power socket and ignition into that.
And the advantage is.....?
By this mod I`ll guess you only make yourself future problems.
11Back to top Go down   Making her pretty. Empty Re: Making her pretty. Sat Jan 21, 2012 12:28 pm
Norfolk_Boi
Norfolk_Boi
Hmmm, your right. I will keep the injection unit where it is. The power socket is fixed in the lid of the under-seat box that holds the unit. I will put the ignition there too to tidy the front end up.
I've nearly finished recovering the seat, it will be finished tomorrow when I re-attach the fixings. The plastic guard will be cut down to the level of the seat rails, I'll fit a metal guard at a later date.
12Back to top Go down   Making her pretty. Empty Re: Making her pretty. Tue Feb 21, 2012 1:35 pm
Norfolk_Boi
Norfolk_Boi
Well I've been slacking I admit. More progress now:
Making her pretty. CopyofDSCN1893
Need to have a metal bar welded across the rear of the frame to give it a wee bit of strength. Also two plates to bolt the seat too as the seat lock and the pin for the seat hinge are gone. Need a rear guard too really. Silencor is gone and she sounds nice 🆒 . May have a little baffling though.
I want to replace the handlebars for wider ones with a higher rise. Maybe stainless/ chrome ones.
