1Back to top Go down   Starter and load shed relay Empty Starter and load shed relay on Sat Mar 28, 2009 7:37 pm
As it is very difficult for most people to follow the full electrical schematic, I made this simpler one about the starter relay and load shed relay.
The function of the load shed relay is to disable lights and accessories to give the maximum power from the battery to the starter.
This may help you to understand how it works as well as troubleshooting a starter not turning.
The way that the load shed relay works is confusing but in fact cleaver.
The relay coil is fed with the positive(+) from the ignition switch on one side and from the ground(-) coming from the starter on the other side(the ground is passing through the inductor of the starter motor). when you push on the starter button, this ground will be switched to positive and the load shed relay coil will then be fed by a positive(+) on both sides (This is like not having power). At this point, the load shed relay will be released and the lights and accessories will go off.
Note: if the gear box is in neutral, the starter button is fed from the digital gear display(power passing through a diode). If not, it is fed by the clutch switch.
THIS IS WHY PEOPLE ARE TALKING ABOUT THE GROUND COMING FROM THE STARTER. If you have a bad starter, your lights, flasher,horn and fan may not be working as the load shed relay coil doesnt get its negative. Smile
Note: When the battery is low, DO NOT TRY TO START THE BIKE. You may end up burning the starter relay (a $130 mistake)
Starter and load shed relay Starte12
2Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay on Wed Mar 04, 2015 8:07 pm
MikeisonTV
MikeisonTV
Thank for this. So I understand a little more about troubleshooting these relays....will the starter attempt to fire the bike, if the relay is faulty? Or not engage at all?
If the load shed relay is faulty, will the bike turn the starter, but not fire the bike?
Thoughts on testing the integrity of them? will using a test light and the battery work or damage it?
3Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay on Wed Mar 04, 2015 10:06 pm
Thanks for posting the diagram, Bert.  Now I finally understand what is going on with the load shed relay.  Didn't realize that it is energized closed to power the circuits it controls and goes normally open when the starter is energized.
One question, though.  Is there supposed to be a ground drawn on the other side of the starter relay coil?
4Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay on Thu Mar 05, 2015 7:22 am
Point Seven Five,
No, the other side of the starter relay coil does not go to ground directly. Bert has exercised artistic license in his drawing and eliminated huge sections of the bike's electrical system for simplicity's sake, including the ICU and ECU. The other side of the coil goes to the ICU. Below 700RPM, the starter coil gets its ground connection through the ICU. Above 700, the ICU prevents the starter relay from engaging for safety.
5Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay on Thu Mar 05, 2015 9:21 am
Cool, info burned to whatever memory I have left.  Still, it would be handy to show the ECU contact with a note about the 700rpm logic.
6Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay on Thu Mar 05, 2015 10:34 am
@Point-Seven-five wrote:Cool, info burned to whatever memory I have left.  Still, it would be handy to show the ECU contact with a note about the 700rpm logic.
Due to average age of K riders certain aspects are committed to memory to force us to remember.......that 700rpm or 710rpm is important.....
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 102,500 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell Now 36,188  miles
7Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay on Thu Mar 05, 2015 6:31 pm
kioolt
kioolt
@MikeisonTV wrote:Thank for this. So I understand a little more about troubleshooting these relays....will the starter attempt to fire the bike, if the relay is faulty? Or not engage at all?
It may or it may not.  It depends on what is wrong with it.
The starter and the bike will fire fine even if you have a bad load shed relay.  The load shed relay has NOTHING to do with the bike starting or running.  It's there to turn off accessories when starting the bike.
I would test them while completely installed with a voltmeter on the output side of the contact.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
8Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay on Thu Mar 05, 2015 7:41 pm
"Due to average age of K riders certain aspects are committed to memory to force us to remember.......that 700rpm or 710rpm is important....."
To be precise 711rpm.....no I don't know and I doubt BMW knows either.
9Back to top Go down   Starter and load shed relay Empty Re: Starter and load shed relay on Fri Mar 06, 2015 3:46 am
MikeisonTV
MikeisonTV
Thanks k100LT
