MT350Explorer
MT350Explorer
Hi Guys,
I'd like to remove both wheels to take to a tyre shop and would appreciate advice on how best to prop up the bike to prevent damage.
Many thanks
Dave
JR_K100RS
JR_K100RS
G'day MT350Explorer ,
yup I always take loose wheels when getting tyres as well , saves scratches from heavy hands , also it's a good idea to ensure when the front wheel is put back in that the forks are parrallel & not binding , what I usually do is to get a scissor jack under the engine as far forward as you can get it ( around the oil filter access cover ) and with a piece of thin wood like ply slowly wind it up until the front wheel lifts clear of the ground , I've never had any probs using this method for the last 25 years with my K
Ciao
JR
Melbourne Australia
Rickmeister
Rickmeister
Same here. Remove the rear wheel. Then, with a jack of any description, and a piece of timber to protect the engine base, and as far forward as possible, raise the jack until the front wheel is off the deck, remove it. The bike is still quite stable in this situation.
I did as above Dave and to be safe a couple of light ratchet straps over the garage joists to the grab handles as a backup.
How should I prop up the bike to remove both wheels? Ir-log1188....May contain nuts!How should I prop up the bike to remove both wheels? Ir-log11
I would vote for a scissor jack over a hydraulic since the weight it is holding up is minimal so breakage is unlikely and unlike a hydraulic jack the seals cannot leak and let it down whilst you are at the tyre shop.
It happened to me with a car, I came home to find the car resting on the brake plate and disk where the jack had gently lowered the car over the two hours I had been away. I use hydraulic jacks but now never rely on them to hold anything up for more than a few seconds to get a jack stand under the thing.
Another option is to use two extended axle stands (I made mine adjustable from 25" to 30") with a bar through the frame to support the back of the bike while the front is jacked up. It makes a stable wide 3 point stand.
With my bike on the centre stand I use an old bottle jack the type that you wind up and the middle screws up I stick an old riggers glove on it and it seats itself nicely on the bottom screw of the water pump so far any wriggling and squirming performed by me has not brought it undone.
Here's a picture, it only took about 10 minutes to set it up this morning....... and reminds me I must get round to painting the frame.... Embarassed
How should I prop up the bike to remove both wheels? Ssl10716
Here is what I use:
How should I prop up the bike to remove both wheels? Statte11
Sidecar Paul: have you tested your setup with the front wheel removed?
(center of gravity is in front of the center stand).
Hi Inge,
The bar is about 8" to the rear of the centre stand pivot, so with a jack under the front of the engine it keeps everything stable with the centre of gravity well within the base of the triangle. As my drive is on a slight slope and I didn't want to remove the belly pan this morning, I didn't take the trouble to jack up the engine. Also if I were removing the front wheel I would use a square bar because the round bar does roll on the frame and the stands.
I use the setup whenever I need to remove the sidecar because with the bike supported from higher up the frame there is less chance of pushing the bike over when persuading the fittings to go back in place.
Cheers,
Paul
Shep
Shep
This week I used a standard motorcycle lift that many of you have to lift both wheels and the bike to a position where I could clean the bike more easily.
Question: Are the points where I chose to support the bike safe without damaging anything?
First of all I used a portable bike stand to hold the bike up so the centre of the bike was free of the two kickstands.
How should I prop up the bike to remove both wheels? K100rs12
The front motorcycle lift support was positioned around the third cylinder on the flat bottom of the engine (towards the rear of the engine). The lowest exhaust header was clear of the lift mechanism.
How should I prop up the bike to remove both wheels? K100rs13
The second lift support was positioned under the main kickstand. It ended supporting the bike via two metal tabs that are just below the centre stand bushings.
How should I prop up the bike to remove both wheels? K100rs14
How should I prop up the bike to remove both wheels? K100rs15
The bike was extremely well balanced both longitudinally and transversely and sat solidly on the lift. I did not remove any tires to check the balance.
The part requiring attention is the lowering of the bike back into the portable stand as the motorcycle lift moves the position of the bike slightly sideways as it raises it away from the portable stand. The front wheel needs to go back into the portable stand so the entire bike is as perfectly vertical as possible (no lean).
So are the lift points okay?
Shep
Model Production Date/Serial Number
K100RS 1984 July/ (F0040448)
K100RS 1986 Dec/ (H0142581)
I was stopped at a friend's house who didn't have a lot of tools and I needed to pull both wheels to get some tires. Solution: Phone books!
How should I prop up the bike to remove both wheels? K11lt.phone.books
I've also borrowed the jack from my dad's car when visiting him.
When I got a flat in The Yukon I just used a big rock from the side of the road:
How should I prop up the bike to remove both wheels? Alaska.rock
I usually just lift the front and slip a bessar block with a piece of timber under the sump. If you need it to get it a little higher, run the front wheel up on a lump of timber first and slide another piece under the centre stand, then jack the sump up.
How should I prop up the bike to remove both wheels? 20141210
1988 K100RT VIN No. 0094680
1989 K100RT VIN No. 0097367 (naked)
1996 K1100RS VIN No. 0451808
How should I prop up the bike to remove both wheels? Austra12 Fuel: 95 Octane
Engine Oil:Nulon Full Synthetic 15W50
Gear Box Oil: Nulon Synthetic 75W90
I find this is an easy method when removing both wheels at the same time . Especially when taking them in for new tread .How should I prop up the bike to remove both wheels? K100_w10
Nigel , how would it go to place a block between the wheels prior to engaging the centrestand, you can raise the bike instantly.
1987 K100RT Ex- police
1989 K100LT Ol' Blue and "Kart" the Kamper trailer. now KAPUT .
1993 K1100RS 0194321 Colour #690 Silk Blue aka" Smurfette"
How should I prop up the bike to remove both wheels? 10_x_110
k-rider
k-rider
a lot of good ideas How should I prop up the bike to remove both wheels? 212902
but come to think of it , i dont recall ever having to change both front and rear tyre at the same time ,there always seems to be at least a couple of thousand km between. Very Happy
k-rider
I've had both of mine minus both wheels at the same time... Shocked One had my engine trolley under the sump and the 'splinestand' I made supporting the rear. The other was held up with concrete blocks and chunks of timber. I still regret not taking a picture! Very Happy
Yep... that's what I do Ed. But I run the front wheel up on a piece of timber first. Makes it easier to pull it up on the centre stand with the timber under it.
"running the front wheel up onto a block of timber" , hadn't thought of that , Nigel
I'm guessing the 1100 will be a different story , as it seems to sit lower , or am I wrong ?
Bumblebee
Bumblebee
I put the bike on the center stand, if I replacing both tires I first remove the rear tire, then using lifting straps pick up the bike from the handlebars and remove the front wheel.
Eazy Peazy.
http://Bugsmashers.org/phpbb
