1Back to top Go down   LED running lights. Empty LED running lights. Wed Apr 11, 2012 5:55 pm
There are a lot of options for LED lights these days but here is how I did mine.
LED running lights. Ssl10611
Start with a Rolson 72 LED worklight.
LED running lights. 03311
Cut the printed circuit board to leave two rows of LED's and trim the chrome strip to suit.
LED running lights. Ssl10728
Fit it into the parking light space after removing the stepped 'reflector' thingy (I cut the centre section out of my stepped thingy to retain the end lumps)
LED running lights. Img_213
Wire it up as this diagram.
LED running lights. K100_l10
Mount the 5V regulator, resistor and relay somewhere on the fairing frame.
LED running lights. Ssl10823
Of course, if you've got a sidecar, make a matching unit for the front!
LED running lights. Ssl10612
And that's all there is to it.
Total cost of items is about £13 (April 2012).
(I did find that replacing the bottom Phillips screw with a 5mm stud makes refitting the headlamp unit easier.)
