1Back to top Go down   Alternative Oil Filter Empty Alternative Oil Filter on Sun Jun 24, 2012 3:15 am
Fraglerian
Needed to change my oil in a hurry. The only local shop likely to be of any use was a Halfords.
They do a filter, CHAMPION C301, price £6.99. It does say on it that it's for BMWs. In the motorbike section.
They also do a tool that fits so you can remove the filter without needing to remove more than the 3 allen screws covering the filter (i.e. not having to remove the next cover and use a strap tool). You just need to have the gumption to push out the central rivet to expose the 3/8 square drive hole. Price £7.99
They fit. The tool and the filter.
If I find a problem (I haven't driven off on it yet, I have a lot more work to do on my 28-year-old, but wonderful bike, I will let you know. I realise there may be more things involved (non-returns etc).
I know little of m/bikes, tho 54, I've always ridden rather than worked on them, so if I'm wrong or misleading people then please slap me down.
Meanwhile, my vast appreciation for all those people who take the time to leave info and help on here for us novices and experts alike. Cheers and happy biking.
Last edited by Fraglerian on Sun Jun 24, 2012 3:21 am; edited 1 time in total (Reason for editing : Spelling and ambiguity.)
2Back to top Go down   Alternative Oil Filter Empty Re: Alternative Oil Filter on Sun Jun 24, 2012 10:24 am
Hi Fraglerian.
A good ides is to put a post in the new members section and tell us about yourself and of course your bike with pics of the bike.
That filter is on my list of filters that work on a K. Most of the aftermarket filters are OK although some do have different values on the bypass valves which really only take effect when the filter is getting dirty and at the end of its life. I change my filter and oil every 5000km which should be often enough to keep the filter working well.
3Back to top Go down   Alternative Oil Filter Empty Re: Alternative Oil Filter on Sun Jun 24, 2012 2:36 pm
One thing to watch out for is cheap filters which have low bypass pressures which can mean for much of the time you are circulating unfiltered oil as the bypass valve is doing just that bypassing the filter.
4Back to top Go down   Alternative Oil Filter Empty Re: Alternative Oil Filter on Sun Jun 24, 2012 5:27 pm
Ned
Ned
@K-BIKE wrote:One thing to watch out for is cheap filters which have low bypass pressures which can mean for much of the time you are circulating unfiltered oil as the bypass valve is doing just that bypassing the filter.
yes, that is true. From memory most common filters are set to by pass around 12-15 psi... one atmosphere. I seem to remember that Mann (?sp) is set above 20 psi. Someone may want to confirm this.
Having said all of that, I use the local brand Ryco (Z418?) because it is easy available and fits K100 well. http://www.rycofilters.com.au/catalogue/product/part/Z418
Ned
5Back to top Go down   Alternative Oil Filter Empty Re: Alternative Oil Filter on Sun Jun 24, 2012 6:31 pm
Champion's C301 is a direct replacement part number for the OEM oil filter for all early K75/100/1100/1200 (but not across-the-frame 1200s) and Oilheads of 1100 and 1150 displacement.
1977 R75/7-R100 grey, '87 K100RS red, '93 K11-K12 aka 'Big Block' black, '96 K1100RS black, '98 K1200RS red, '09 K1300GT red, & 2013 R1200RT-Polizia black & white.
