1Back to top Go down   Front rubber engine mounts Empty Front rubber engine mounts on Sat Jul 14, 2012 4:59 pm
smoll1
Hi all
I have managed to get the frame sprayed at last and went to put the new front rubber engine mounts and forgot to take pictures of which way round they go.
When I work out how to download pics on here i will post let see how progress is going slowly ha:)
The mount has bmw writing on one side and the other is the mount with wider metal part.
Hope some one can help:D Very Happy
2Back to top Go down   Front rubber engine mounts Empty Re: Front rubber engine mounts on Sat Jul 14, 2012 5:16 pm
Try going to http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx
Make sure you have your vin number and then you can look up the exact part number.
3Back to top Go down   Front rubber engine mounts Empty Re: Front rubber engine mounts on Sat Jul 14, 2012 5:17 pm
Front rubber engine mounts Mounti10
I cannot see any reference about the way that they are on the bike.
Are the shoulders having a different thickness?
From what I recall, they are symmetrical and I believe that they can be installed either way.
CF
Front rubber engine mounts Frog15Front rubber engine mounts Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML sidecar.
4Back to top Go down   Front rubber engine mounts Empty Re: Front rubber engine mounts on Sat Jul 14, 2012 8:55 pm
Brickee
Brickee
Just be aware that the frame doesn't straddle the engine, it mounts to the left side of the engine mounts looking from the front. Also, if memory serves, one of the shoulders is larger and goes to the engine side. They're a hard rubber, so what I did was to heat them up by putting them close to a halogen work lamp, coat them w grease and use a C clamp to pull/push them into the frame. It worked for me, but maybe someone else has an easier way in putting them in.
86 K100RT VIN 0053533
The good news is, I no longer have senior moments. The bad news is, now it's a constant state of mind.
5Back to top Go down   Front rubber engine mounts Empty Re: Front rubber engine mounts on Sat Jul 14, 2012 9:08 pm
Front rubber engine mounts Foring10
6Back to top Go down   Front rubber engine mounts Empty Re: Front rubber engine mounts on Sat Jul 14, 2012 9:29 pm
kfilipow
kfilipow
Inge K. you are amazing, always have answers and pictures. Plus, by my calculation it is about 2:30 am in Norway. Must work nights.
7Back to top Go down   Front rubber engine mounts Empty Re: Front rubber engine mounts on Sat Jul 14, 2012 9:33 pm
There is no night in Norway at this time of year he hibernates in winter.
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats." from Mencken's 1919 Prejudices
8Back to top Go down   Front rubber engine mounts Empty engine mount on Sun Jul 15, 2012 5:25 am
smoll1
Thanks for the info all, I will fabricate the tool in the picture and see how it goes I will keep you posted Very Happy Very Happy Very Happy it was the shoulder that i was concerned with but think that answer will help.Razz
9Back to top Go down   Front rubber engine mounts Empty urethane bushings on Tue Feb 13, 2018 1:43 pm
woodgeek
woodgeek
Has anyone measured the factory rubber engine mount? Energy Suspension makes a number of universal urethane bushings. Maybe something can be used in place of the $50 factory part.
http://energysuspension.com/universal-products/link-flange-type-bushings-universal-mounts-isolators.html
Front rubber engine mounts Universal%20Link-Flange%20Type%20Guide
10Back to top Go down   Front rubber engine mounts Empty Re: Front rubber engine mounts on Fri May 04, 2018 5:52 pm
@kustom_moto
@kustom_moto
I must be very stupid because I cannot work out from this photo what way around this rubber grommet goes!!
