1Back to top Go down   Parts for K1100LT Empty Parts for K1100LT on Thu Aug 09, 2012 4:14 pm
STEVE1959
I am selling some K1100LT parts for for a friend. There is a front and rear wheel, both are in very good undamaged condition. The front has the ABS discs on it, one measures 4.8mm and the other 4.9mm. Both wheels will clean-up O.K. the front having a fair amount of road grime on it. But otherwise they are pretty well unmarked not even any tyre fitting marks. The second part is a complete para-lever with the swinging arm and drive unit it also comes with the two piece drive shaft and this is a very low mileage unit. Last is a BMW Showa rear shock which may be of use to someone. PM me if you have any questions
2Back to top Go down   Parts for K1100LT Empty Re: Parts for K1100LT on Thu Aug 09, 2012 5:47 pm
hmm three spoke type steve ? im interested ....in the front
i better check if its the floating disk type may not fit my older k100 ....doh !
rick ? inge ? any advice ?
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OParts for K1100LT Au-log10
3Back to top Go down   Parts for K1100LT Empty Re: Parts for K1100LT on Thu Aug 09, 2012 7:34 pm
Is the rear drive a 33/12, stamped near the breather.
4Back to top Go down   Parts for K1100LT Empty Re: Parts for K1100LT on Thu Aug 09, 2012 10:21 pm
nino
Steve, does the 1100 shock fit K 100?
5Back to top Go down   Parts for K1100LT Empty Re: Parts for K1100LT on Thu Aug 09, 2012 10:24 pm
@nino wrote:Steve, does the 1100 shock fit K100?Thanks
It does if you don't mind the extra lift, and you have the required inseam...Paralever shocks are significantly longer than Monolever shocks.
I'm practicing social media distancing; no Facecrack, Wazzup or Instagreedy!
1970 R60/5, '77 R75/7-R100, '85 K100'87 K75C, '87 K100RS, '93 K11-K12 Big Block, '93 K1100RS, '95 R100-Mystic, '96 K1100RS, '98 K1200RS, '00 K1200RS, '02 K1200RS, '03 K1200GT, '04 R1150R'04 R1150RT, '05 K1200S, '06 K1200R, '07 K1200R, '09 K1300GT & 2013 R1200RT-Polizia  - the Beemers in my life I can recall, owned still or sold on, since 1976.
6Back to top Go down   Parts for K1100LT Empty Re: Parts for K1100LT on Thu Aug 09, 2012 10:47 pm
Charlie: you`re correct, the 305mm floating discs won`t fit.........
you better search a complete front end.......
or a three spoke from a 75, some spacers and bits.
Nino: an add to GITH`s info, the para shock is 30mm longer.
7Back to top Go down   Parts for K1100LT Empty Re: Parts for K1100LT on Thu Aug 09, 2012 11:00 pm
@charlie99 wrote:hmm three spoke type steve ? im interested ....in the front
Charlie, I know a private source in the States where you can get a three spoke 18" front wheel from a K75S (and an option on the other models at the time, like mine) that's in good nick and which will accept your 285mm brake discs and calipers, no worries.
I just located this complete front end (41.7mm Marzocchi) from a 16V K100 for a total of US$120 shipped to my workplace! 17" front wheel and 305mm brakes, here we come...
Parts for K1100LT K100_110
If you know where to look the things you desire badly enough can be found...
8Back to top Go down   Parts for K1100LT Empty Re: Parts for K1100LT on Fri Aug 10, 2012 7:46 am
STEVE1959
Rick, the ratio is 31-11 and Charlie the discs are the floating type.
Last edited by STEVE1959 on Fri Aug 10, 2012 7:52 am; edited 1 time in total (Reason for editing : added information)
9Back to top Go down   Parts for K1100LT Empty Re: Parts for K1100LT on Mon Aug 20, 2012 3:42 pm
STEVE1959
10Back to top Go down   Parts for K1100LT Empty Re: Parts for K1100LT on Mon Aug 20, 2012 3:44 pm
STEVE1959
11Back to top Go down   Parts for K1100LT Empty Re: Parts for K1100LT on Mon Aug 20, 2012 3:46 pm
STEVE1959
Parts for K1100LT Bmfw15
