1Back to top Go down   replace exhaust system Empty replace exhaust system on Fri Jun 05, 2009 5:56 am
french'k
french'k
hi
scuse my bad english.....
is it possible to replace a exhaust system of my K100, by a exhaust system from a K1100
some body said me that I must change the fixation , because it isn't exactly at the same place...
had somebody hear do that adaptation ...
A friend sell me a exhaust from k11 for a little price, mine do strange metal noise now and must be change ...
https://redcdn.net/ihimizer/img37/7109/signatureark.jpg
2Back to top Go down   replace exhaust system Empty Re: replace exhaust system on Mon Feb 15, 2010 11:57 am
Webberle
It is true, the fixation of the K11 exhaust is different. I would sell the K11 exhaust for big money and get 3 k100 "square-exhausts" for that money Smile
Probably it is only the heat-shield which makes a rattling noise.
3Back to top Go down   replace exhaust system Empty Re: replace exhaust system on Tue Feb 16, 2010 9:06 am
beachcomber
beachcomber
All exhausts [ 4 cylinder ] will interchange with some degree of modification [ minor].
I am developing a system with Keihan for my Streetfighter and Race Rep and they have taken the opportunity to use that to develop a replacement system for Kays.
It's been trialed on my K100RS and is now going on my K1100RS for 3K miles road testing. The system will be able to fit both models, and unlike mine - you can keep all the standard parts - luggage, pegs, etc.
All are based on a 3 piece system - downpipes, 4 into 1 collector and silencer. Unlik the Remus system - the outlet is for "normal" silencers, so you can retro fit anything of your choice.
4Back to top Go down   replace exhaust system Empty Re: replace exhaust system on Tue Feb 16, 2010 1:56 pm
green cat
green cat
Hello beachcomber, i'm very interrested in you plan... the exhaust of my K11 is broken and the only expensive solution is the Remus one....
[img]replace exhaust system 3cc2228804714fdc8e93fe1f84a93706 [/img][img]replace exhaust system K1100l10
5Back to top Go down   replace exhaust system Empty Re: replace exhaust system on Tue Feb 16, 2010 4:46 pm
beachcomber
beachcomber
Bonjour Chat Verte.
Yea - that's the reason I looked at exhaust alternatives - the cost.
The other problem with the Remus system is that you must use the Remus can. With the system we are developing you can use a "normal" can when the Keihan one needs replacement.
Also - the downpipes are seperate - so all parts can be replaced on their own.
There is NO catalyser with these systems.
When I find out how to post pix, I'll put some on for you.
We are maybe 6 -8 weeks from testing the system on the road [ Minimum 5K kms.]
keep looking!
TJ
6Back to top Go down   replace exhaust system Empty Re: replace exhaust system on Wed Feb 17, 2010 4:46 am
green cat
green cat
Thanks!!!
