1Back to top Go down   Phantom part found in my 'bits' box Empty Phantom part found in my 'bits' box on Sun Sep 02, 2012 9:17 pm
I found this part in my 'bits I should know where they go it is so obvious I don't need to label them' box
I should have labelled it. No idea what it is or even if it is for the bike.
Any guesses?
Phantom part found in my 'bits' box Phanto10
Phantom part found in my 'bits' box Phanto11
rossco
2Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Sun Sep 02, 2012 10:51 pm
I think it is part of the Fino family....Buggeredi or Stuffdi or it could be that sister, can't remember her name...starts with F.
3Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Sun Sep 02, 2012 11:53 pm
Gees I've had a few K apart and I don't recall anything like that.
4Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Mon Sep 03, 2012 12:13 am
It has oil on it.
5Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Mon Sep 03, 2012 11:05 pm
beanoldboy
beanoldboy
it looks to me like the rear axle spacer/indicator off a chain drive bike.
http://www.airware.com.au
6Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 1:36 am
walfish
walfish
If the bolt hole suits an 8mm bolt,then it is from the headlight adjuster for a naked K(round headlamp)
Phantom part found in my 'bits' box Uk-log10 88 K 100  0033026
                            92 K 1100 LT  6455097
7Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 2:08 am
Perfect.
A parts bike I have was a K100.
Part #12
Phantom part found in my 'bits' box 1410
Thanks Ungaas
8Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 2:42 am
That explains why I have never seen one, I've never had that apart.
9Back to top Go down   Phantom part found in my 'bits' box Empty Phantom part found in my 'bits' box on Tue Sep 04, 2012 7:20 pm
Rossco, how long did you study the patrs list to find that ?. And I'm waiting for your explanation as to how oil gets way up the front there.
Cheers mate, Bargo pie shop coming up soon by the look of this weather.
10Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 8:36 pm
Ungaas said what it was from and the previous bike was a naked K.
And I have honed my skills in searching realoem so I can get in before Inge.
The reason I did not recognise it was the headlight surround and mounting came off the bike in a box so I never actually removed the part myself.
If you had seen the condition of the bike when I got it you would understand why/how it has oil on it.
Bargo pie shop does sound excellent. My next trip there will be riding, not driving Smile
Unfortunately the back of the bike is off and waiting for parts.
Going to pull the clutch off again and re-fit it.
I was not happy when I put it back on and now have to wait for the bolts to arrive.
How do I stop the motor turning while doing up the clutch bolts?
rossco
11Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 8:40 pm
There are several places you can jam a block of wood to stop it turning but it can be very painful if you get a splinter.
12Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 8:49 pm
rossco wrote:And I have honed my skills in searching realoem so I can get in before Inge.
You don`t need much effort, everybody I know always says that I must be the slowest person on earth.
Use the fiches on MaxBmw instead, much easier.
Good luck with clutch!
13Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 8:54 pm
If you want some hex head bolts go to REPCO, they have some 7mm thread bolts on the "champion" stand with a selection of bolts 7mm x 35mm or 7mm x 50mm and cut them down and that way you don't strip the head out.
14Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 9:50 pm
dalderton
dalderton
rossco wrote:I found this part in my 'bits I should know where they go it is so obvious I don't need to label them' box
Any guesses?
Rossco. Are these parts needed by yourself as I have one missing from my 85 K75c I did not recognise them until they were put into context but now it it all becomes clear. I would be happy to buy one or both if you dont want them if they are surplus to requirements,
Regards Dennis.
rossco
1985 K75c Stock other than Realm Engineering Rear Shock.
15Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 9:55 pm
Thanks Rick,
Question is do I still torque these up the same? I am guessing they are not stretch bolts?
Or do I just tighten the crap out of them and be happy with that?
Reason I ask is I had all kinds of dramas putting the clutch back on. The engine was sitting on the floor (it is in the frame now) and it was rolling round and pistons going up and down.
I never got the correct torque setting on any of the bolts.
I am hoping this is the source of my 2800rpm vibration.
rossco
16Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 9:59 pm
Hey Dennis,
I promised the lot to K75cster. You will have to fight it out with him.
Headlights at 20 paces Rolling Eyes
17Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 10:01 pm
yankeeone
Nice job naming the part, I would not have come close.
18Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 10:03 pm
rossco wrote:Thanks Rick,
rossco
I just pull them up till my elbow goes click and use some locktite thread lock. To get them out a bit of heat from a butane torch and they come easily.
19Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Tue Sep 04, 2012 10:22 pm
[/quote]
I just pull them up till my elbow goes click and use some locktite thread lock. To get them out a bit of heat from a butane torch and they come easily.[/quote]
Sounds like a plan
20Back to top Go down   Phantom part found in my 'bits' box Empty Re: Phantom part found in my 'bits' box on Wed Sep 05, 2012 12:53 am
dalderton
dalderton
rossco wrote:Hey Dennis,
Thats OK First in best dressed.
Regards Dennis.
