1Back to top Go down   88 K100 cleanup and paint work. Empty 88 K100 cleanup and paint work. on Thu Jul 09, 2009 6:25 pm
downssm
downssm
This job is being done in a small shed with basic tools. A lot of pictures just don't turn out in the poor lighting and not so good camera.. Will add as I can.
http://cid-65cee5538b51e059.skydrive.live.com/browse.aspx/K100
Please let me know if this link works or not!
Steve
2Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Fri Jul 10, 2009 3:53 am
phil_mars
Hi Steve, link is fine and I look forward to the finished product.
Phil
3Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Fri Jul 10, 2009 5:08 pm
Good on you for doing it and the photos have good depth of field on the engine and are sharp. Love the dog!
4Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sat Jul 11, 2009 7:02 pm
Bruce
Bruce
Looks like you're having fun!! Sometimes the work is the reward!
5Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sun Jul 12, 2009 7:30 am
Cablebeacher
Hi Steve
(been there, done that...) It is looking good. Good luck! I am in the process of putting some of my re-build pictures on the site. A little bit of advice and take it with a grain of salt... it looks like you masked around the BMW logos on the tank? I went through the same thought process but found new logo stickers were quite cheap (approximately $A10 from memory) so it was "easier" to take the old one's off and replace with bright, shiny new ones...
Mal
6Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sun Jul 12, 2009 7:31 am
Cablebeacher
Hi Steve
Mal
7Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sun Jul 12, 2009 6:13 pm
downssm
downssm
Nope... Everything was removed from the bike before any sanding or painting was done. In most cases I had to take the parts down to original material, plastic/metal because the bike was originally white, then black, but not a real good job. Those are new roundels not stickers. They are not quite perfectly round, one has two flat spots. But I was not going to risk trying to trim them. I can replace those later when I find some better quality bits. They were very cheap thru E-Bay, $4. I know... Ya get what ya pay for!
I am working on the headlight mounting now. Trying to make a good looking mount. The mounting location on the fork triples is a little hard to fit a bracket too! Anyone have any ideas or extra naked headlight brackets??
Thanks for the comments!
Steve
8Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Jul 29, 2009 6:03 pm
downssm
downssm
I have added some pics of the highrise fender with a different stripe style. Tell me if it's ok or too much!
9Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Jul 29, 2009 8:30 pm
phil_mars
Hi Steve I am not sure about the fender but that is a personal thing so if you like it then that is all that matters. I have to say the as a whole it looks pretty damn fine and I think I said somewhere else that it would be lighter than a current GSA which is a statement in itself.
Are you planning some sort of bash guard as we would not want the water pump and hall sensor exposed to too much debris.
A closeup of the headlight set-up would be interesting and are the forks standard as they look longer than normal.
Phil
10Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Aug 05, 2009 5:35 pm
downssm
downssm
Thanks Phil,
Still looking for a guard and radiator shroud. Standard forks as far as I know. Waiting for a small naked style fairing from a friend to see if that will work. One of the hard parts is hiding the wiring, even if it's shortened it's a mess to hide!
Looking for gaitors and still hoping someone needs LT fairing bits and has naked bike parts to trade. We have had so much rain it's been hard to get anything done this summer.
Will be getting rid of the fairing and it's parts and the radio. Keeping the side bags and mounts.
The paint is more done "to taste" but if I have had just enough beer everything looks good! Even the pearl I tried, and that came out pink! So I need second and third opinions!
Steve
11Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Aug 05, 2009 8:20 pm
phil_mars
Hi Steve,
It is amazing how beer and/or distance improves the look of all sorts of things Rolling Eyes
but as far as the wiring goes you could try wrapping in self amalgamating tape which will give a black finish and a very professional look assuming you can get easy access to it of course.
Phil
12Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sun Aug 09, 2009 10:44 am
downssm
downssm
Phil,
Are refering to what I was taught to call pressure sensitive tape. Is that a cloth fiber tape with a tar like substance that sticks to itself even when wet? Found alot in older cars.
Going to try wire looms first as they are cheap and easy. Hopefully they will do the trick.
I need to clean the wire connections anyway so shortening while re-soldering the wires might as well be a part of that process.
Has anyone tried a product called plastic dip? It comes in a 1 pint or quart can and is used to re-coat things with a heavy rubber covering. Like the handle of a pair of pliers. It also comes in a spray and works very well on scratched plastic parts and leaves a thick rubber coating which stays on and is easily repaired. You could spray it on almost any surface you need refinished. Especially for a quick fix. Of course I have no information on is durability over a long period yet when used on a bike. Yet!
Please keep sending me ideas everyone!
Steve
13Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sun Aug 09, 2009 8:10 pm
phil_mars
Hi Steve,
According to K-Bike it is "polyisobutylene tape" and I used to call it bi-seal but it is a rubberised tape not cloth based but good stuff nonetheless.
Plastic Dip sounds interesting.
Phil
14Back to top Go down   88 K100 cleanup and paint work. Empty more pics on Sun Aug 23, 2009 7:01 pm
downssm
downssm
Added a few pics to the same link above... The tank, rear fairing, side cover, front fender just sitting on the bike.... Is it too bright?
15Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sun Aug 23, 2009 7:23 pm
It looks good, but personally I would paint the back of the front mudguard too.
Just a personal opinion.
Bert
16Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Mon Aug 24, 2009 5:39 pm
downssm
downssm
I will look at that again when the fender is up higher in it's real position. It is black because it was before, that fenders' off of a Suzuki -ES. The K100 Fender is all white as in other pics. I also have a fender extender I could add to it. Thanks for the input!
Still looking for some C model front side covers/radiator shroud for under the tank. A headlight is inbound..
Steve
17Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sat Oct 10, 2009 3:45 pm
downssm
downssm
Headlight shroud is done. Square and it fits just under the gauge cluster. Will post more pics soon. Still need radiator shroud. Also.. Second set of rims is inbound, allowing a second set of tires, dual sport, and the original to be powder coated. Much better than my in shed paint job...
Spending alot of time waiting for the right parts to be located. But even though my schedule has been trounced several times it's been fun.
18Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Tue Oct 13, 2009 2:32 pm
Here is some ideas to finish your street fighter project....
88 K100 cleanup and paint work. Bmw-k710
88 K100 cleanup and paint work. Dietma10
88 K100 cleanup and paint work. Ronny_10
Notice the nice center stand..... Pretty good idea to work on the bike.
88 K100 cleanup and paint work. Stefan10
88 K100 cleanup and paint work. Reiner10
88 K100 cleanup and paint work. Frog1588 K100 cleanup and paint work. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
19Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Tue Oct 13, 2009 6:17 pm
downssm
downssm
Hey thanks for sharing the pics! Nice! I was wondering about cutting off the tabs mounts on the tank or keeping them in case I found a good radiator shroud. Looks good without. Lots to think about! Nice dolly!
V/R
Steve
20Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sat Oct 24, 2009 8:04 am
Have you visited this site: Very special K bikes
21Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sat Oct 24, 2009 7:24 pm
downssm
downssm
Very nice pics. Thanks!
That special looks like the key switch was placed on the Air box. The 1100 shows how the radiator looks with a fairly plain screen. Two very nice ideas!
I was looking for a place to relocate the ignition switch, get rid of that panel and clean up that handlebar area. Still unsure about the screen -vs- the shroud around the radiator though!
V/R
Steve
22Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sat Oct 24, 2009 7:33 pm
downssm
downssm
Bert,
I keep seeing good ideas in those pics... Chrome wheels, exhausts, trick paint and trim, nice air intake ideas,.... I actualy thought about the headlight and ears off an old scooter to put the gauages up front. Nice to see how it would have looked!
Glad it is taking so long because I would have missed all of that! Now I just need a few $ and a few beers to decide! Thanks again.
Steve
23Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Fri Mar 12, 2010 4:42 pm
downssm
downssm
A fellow I work with, has a shop with a powder coat system. I never knew he had it. He now has my tank and wheels to be redone. So the project is backed up a bit longer.
Steve
24Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sat Mar 13, 2010 1:49 am
phil_mars
Got to say the black one looks stunning.
25Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Fri Mar 26, 2010 10:18 am
downssm
downssm
The K100 is still in bits on the floor of my shed. Getting the tank and wheels powder coated has made me realize I need to re-due the frame and other parts to get a nice match..... SO... It may be a while before she is on the raod again. Doing a few parts at a time with the powder coating.
So...I went out and got a Triumph speedmaster, a 2007 with 3500 on the ticker, $4500. Guys these things are so low cost, it might be worth a look as a second machine. Carbs and electronic pickup, simple design.
Not giving up on the K100 just scratching the itch and giving myself time to do it right!
Does anyone else have a Triumph and what were/are your experiences? My research has found alot of positive feedback.
V/R
Steve
26Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Fri Mar 26, 2010 11:56 pm
phil_mars
Hi Steve,
I think if I could get a speedmaster that cheap here I would have one tomorrow. What a bargain.
Phil
27Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sat Mar 27, 2010 4:18 am
Hi Phil,
If you want to get depressed look up the price of an S1000RR is Aus or NZ and do the conversion they are 13KUS$ in the US do the conversion and get angry about being ripped off, it made me wild.
28Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sat Mar 27, 2010 7:21 am
phil_mars
Hi K-Bike,
A long time ago I remember bikes in Aus did not attract import duty as they had no local market to compete with which seemed a fair and logical thing to me but somewhere along the line one of our wonderful governments changed the policy leading to the prices we have here now.
Now don't get me started on the price of fuel.
Phil
29Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Sat Mar 27, 2010 3:25 pm
Hi Phil,
It is largely down to the margin that the importer chooses to place on the machine, sadly the same applies to car bits, in particular Volvo it seems that as soon as there is an Australian distributor they try to gouge. The Bilstein shock absorber is a classic example, in NZ we get those via Australian distribution and when I wanted three sets (12 shocks) for our Mercs the price they wanted to sell them for shipped via sea freight to and from Australia and three months delivery to their warehouse for pickup was DOUBLE the price for me to get them airfreight from the US and that took just under seven days to my door!
30Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Mar 16, 2011 12:31 am
Oldgoat
Oldgoat
Wow, some fantastic custom rides! Shocked
31Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Mar 16, 2011 12:39 am
Oldgoat
Oldgoat
Anyone know where to get those fork guards on that black beauty?
Thanks,
OG
Last edited by Oldgoat on Wed Mar 16, 2011 1:11 am; edited 2 times in total (Reason for editing : update)
32Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Mar 16, 2011 6:43 am
If you are talking about the fork boots, they are from the early GS (1990).
33Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Mar 16, 2011 11:21 am
Oldgoat
Oldgoat
88 K100 cleanup and paint work. Screen16
Looks like they are some kind of hard plastic Bert.
Last edited by Oldgoat on Wed Mar 16, 2011 12:11 pm; edited 1 time in total (Reason for editing : update)
34Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Mar 16, 2011 4:32 pm
Yes they are hard plastic and I saw them before. I believe they are from BMW but cannot find them on my catalog. You should question a dealer.
Sorry
35Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Mar 16, 2011 4:35 pm
Oldgoat
Oldgoat
No worries Bert as I couldn't find them either. Maybe I'll check with TWB at that master parts CD he has.
OG
36Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Mar 16, 2011 6:14 pm
Oldgoat
Oldgoat
No joy at the dealer yet either Bert. I'll keep you posted!
OG
37Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Tue Mar 22, 2011 7:00 pm
Oldgoat
Oldgoat
Hey folks just found these today! Just need to confirm they would fit the K75 fork diameter.
http://www.traxxion.com/ConventioalForkGuardKit.aspx
OG
38Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Tue Mar 22, 2011 9:31 pm
Wow, they look the duck's guts!
I'll try and hunt some down here in Oz.
39Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Mar 23, 2011 7:42 pm
Oldgoat
Oldgoat
Let me know what brands you come up with down under Blakey!?
OG
40Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Wed Mar 23, 2011 9:21 pm
Hey really cool a K100GS I just might make one. Cool
41Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Thu Mar 24, 2011 12:17 am
I could be barking up the wrong tree, but I'm going to try some off-road bike shops to see if they have anything that may be suitable.
42Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Thu Mar 24, 2011 10:03 am
good idea blakey .....not everyone has in stock ...all the good things
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%O88 K100 cleanup and paint work. Au-log10
43Back to top Go down   88 K100 cleanup and paint work. Empty Re: 88 K100 cleanup and paint work. on Thu Jul 28, 2011 10:36 am
@downssm wrote:This job is being done in a small shed with basic tools. A lot of pictures just don't turn out in the poor lighting and not so good camera.. Will add as I can.
Steve
Nice work mate, but wondering which head lights you used for the scrambler?
