1Back to top Go down   K100RT Slipstream Deflector Empty K100RT Slipstream Deflector on Mon Oct 08, 2012 8:44 pm
wngnutmv
wngnutmv
I'm looking for a new slipstream deflector (Part number 46631453174). Mine has yellowed and I've wet sanded with 600 and then 1000 grit for about 3 hours. It is a little less yellow but not clear enough to use. Is it possible that it has yellowed all the way through?
I found one at a BMW dealer (their website says they have it in stock anyway) for $75.00 plus shipping. Just wondering if anyone knows of a less expensive option. Call me cheap
I've looked at other posts on here with some suggestions for aftermarket windscreens, but this is for the European version and I really like it looks and effectiveness.
Thoughts?
Mike
"Wingnut"
85 K100RT (VIN 0D50672) 70,000+miles
"Gretchen II" (Gretchen von Gearshiften)
2Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Mon Oct 08, 2012 10:53 pm
try "brasso" to get rid of the yellowing
worked for me
and cant hurt at this stage
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OK100RT Slipstream Deflector Au-log10
3Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Tue Oct 09, 2012 1:42 am
walfish
walfish
I've also heard of some guys using "toothpaste"on their screens. Not that I've tried it though.
K100RT Slipstream Deflector Uk-log10 88 K 100  0033026
                            92 K 1100 LT  6455097
4Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Tue Oct 09, 2012 2:05 am
Some sort of mild abrasive, I suppose.
I can say though, that Brasso is more effective than Silvo...
It's true.
Actually, I don't think $75 is so outrageously expensive.
I was watching a Staintune muffler on Ebay here...it went for $272.78.
I bought a screen for my RT on Ebay awhile ago...paid $30 ( One will come up if you're patient)
Fact is though, I had to go out and buy some Brasso to clean it up properly.
It looked ok in the photos!
Sean.
5Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Tue Oct 09, 2012 3:23 am
nino
6Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Tue Oct 09, 2012 8:19 pm
wngnutmv
wngnutmv
Going to give Brasso a try and if that doesn't work then the Motorworks link will come in handy.
Thank you!
Mike
"Wingnut"
7Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Wed Oct 10, 2012 11:17 am
@wngnutmv wrote:Going to give Brasso a try and if that doesn't work then the Motorworks link will come in handy.
Thank you!
Don't be afraid to go hard on it wngutmv. It is strong material. I did a before'n'after . I think you'll find some other posts on polishing if you search the forum. You will need to cut it back a good bit to see if the yellow UV damage is gone all the way in, so a buffer wheel etc would be an advantage. The lip is the hardest to do mechanically because of the shape but on mine it actually cleaned up the best.
K100RT Slipstream Deflector Ir-log11 88....May contain nuts!K100RT Slipstream Deflector Ir-log11
8Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Wed Oct 10, 2012 12:35 pm
nino
Thank you!
It looks very nice with new deflector. Refresh look of screen
9Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Wed Oct 10, 2012 5:42 pm
As some of the RS's have a black screen and deflector, I've been thinking about painting them blue on my solo RS.
Has anyone tried painting them?
10Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Wed Oct 10, 2012 6:28 pm
nino
@sidecar paul wrote:As some of the RS's have a black screen and deflector, I've been thinking about painting them blue on my solo RS.
Yes me. In black. I didnt like the result
11Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Wed Oct 10, 2012 8:14 pm
wngnutmv
wngnutmv
" I did a before'n'after" 88KE, that gives me hope! Thank you!
Mike
"Wingnut"
12Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Wed Oct 10, 2012 11:50 pm
Toto_jp
You could always try window tint
K100 RS 1986
13Back to top Go down   K100RT Slipstream Deflector Empty Re: K100RT Slipstream Deflector on Thu Oct 11, 2012 12:33 am
great idea toto
