1Back to top Go down   I need an instrument cluster top cover Empty I need an instrument cluster top cover on Thu Oct 18, 2012 4:01 pm
Halo
Halo
The perspex on the dash was badly damaged (cracked) on my old girl, does anyone have the top instrument cluster plastic in good nick they can part with ?
Halo
84 K100RS 0014803
93 FZR1000 EXUP
Albyalbatross1
Albyalbatross1
me thinks there be one in the madlab. have a look in the AM for you. Might even be a whole case with gore-tex breather on the back.
Halo
Halo
Cheers Alby Smile
Halo
84 K100RS 0014803
93 FZR1000 EXUP
4Back to top Go down   I need an instrument cluster top cover Empty Re: I need an instrument cluster top cover on Fri Oct 19, 2012 11:11 pm
Albyalbatross1
Albyalbatross1
Halo, It has no real scratches or cracks.. It does not have the gor tex breathers in the back. Both front and back are usable. yours if you want it.
I need an instrument cluster top cover Instru10
5Back to top Go down   I need an instrument cluster top cover Empty Re: I need an instrument cluster top cover on Sat Oct 20, 2012 12:01 am
Make sure they are the same as there are 7 & 9 screw cases. That means the number of screws that hold the two parts of the case together, they go in from the rear. The change was around the end of 1986 from memory.
6Back to top Go down   I need an instrument cluster top cover Empty Re: I need an instrument cluster top cover on Sat Oct 20, 2012 12:03 am
ReneZ
ReneZ
If Halo has no need I'd like to have it. Mine is cracked as well..........
Alternatively anybody reading this has a spare for me? Please advice by PM, thanks.
Greetings from Florida! Having a 'new' K  :cyclops:    Surprised-o:
Rene
BMW K100 - 1985 (0030029) I need an instrument cluster top cover Rain
BMW K1200GT - 2003 (ZK01223)
Albyalbatross1
Albyalbatross1
@Rick G wrote:Make sure they are the same as there are 7 & 9 screw cases. That means the number of screws that hold the two parts of the case together, they go in from the rear. The change was around the end of 1986 from memory.
yes they are. 9 screw..
Halo
Halo
Fantastic Alby I will PM you
84 K100RS 0014803
93 FZR1000 EXUP
