1Back to top Go down   1985 K100RT Parts Empty 1985 K100RT Parts on Wed Dec 19, 2012 7:26 pm
frogy
frogy
Still have some parts left from turning my RT to a Naked.Side cases,radator plastic cover,licenseplate/mudgrd,L/R side battery covers,front fender,and a few other small parts.You can email me for pics.
...oops,also tail section,rack,rear turn signals,side case brackets.
Rack is sold
2Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Wed Dec 26, 2012 8:18 pm
tio Jaimito
tio Jaimito
I am looking for a mounting bracket for top case/backrest for my 85rs. Do you think you may have something that would work? My top case is the simple rectangular one that mounts to the small support on my ducktail, My case has a hole in the center of the bottom, and a twist pin with washer with lock pins that would go thru the hole and hook into some sort of bracket, which apparently vibrated loose and was lost. My case looks like it took a tumble, one of the corners was burned off. But I have the pin, case but no bracket. I would be interested in the bracket or the whole set up if you have it?
UJ
http://www.nachicagonorth.com
3Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Wed Dec 26, 2012 10:01 pm
tioJaimito '85 K100rs wrote:pins that would go thru the hole and hook into some sort of bracket, which apparently vibrated loose and was lost.
Can't help you with the bracket....but here is a picture, so you know what to look for.
(click on picture to enlarge).
4Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Wed Dec 26, 2012 10:35 pm
Hi UJ here is the bit that you want I think (stall available it would seem) Part number two was the one you were referring to?
1985 K100RT Parts 3
Sponsored links
No.DescriptionSupplementQty From Up To Part NumberPriceNotes Photo
01Set mounting parts
46542316755$91.25
02Mounting plate
46542300449$45.31
03Washer
2
46542300447$8.22
04Washer131
07119936442$1.48
05Screw plug
46542300445$43.12
5Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Thu Dec 27, 2012 7:05 pm
frogy
frogy
Sorry I took so long,no I no longer have that piece it was sold with the top case.
6Back to top Go down   1985 K100RT Parts Empty need center stand mounts on Thu Dec 27, 2012 8:58 pm
excorcist
excorcist
Hi, I need the Bolts that mount the center stand along with whatever hardware ius needed to mount it (my bike came with only the stand) please let me know if you have it and how much, Thanks!
7Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Thu Dec 27, 2012 9:42 pm
tio Jaimito
tio Jaimito
@K-BIKE wrote:Hi UJ here is the bit that you want I think (stall available it would seem) Part number two was the one you were referring to?
1985 K100RT Parts 3
Sponsored links
46542316755$91.25
02Mounting plate
46542300449$45.31
03Washer
2
46542300447$8.22
04Washer131
07119936442$1.48
05Screw plug
46542300445$43.12
Exactly, I would also probably need part three, but as you said I will check the local dealer to see if they have it. I am voting for Kbike
8Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Thu Dec 27, 2012 9:54 pm
tioJaimito '85 K100rs wrote:Exactly, I would also probably need part three,
Part #3 is attached to the bottom of the twist pin, turn the top case upside down to check.
(You also see a picture of the bracket in post #3).
9Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Fri Dec 28, 2012 12:02 pm
frogy
frogy
@excorcist wrote:Hi, I need the Bolts that mount the center stand along with whatever hardware ius needed to mount it (my bike came with only the stand) please let me know if you have it and how much, Thanks!
Sorry but I am still using the center stand and just had it powder coated.Could not believe the amount of rust that fell out of it,but it sounds solid when I whack it with a hammer all over:D
10Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Fri Dec 28, 2012 12:53 pm
tio Jaimito
tio Jaimito
Inge, Thanks for your help. It seems that my top case has a hole about 25mm in the bottom center. Perhaps this hole used to be smaller. There is no washer or any metal below. and the bracket is also missing from the bike. Perhaps, my whole topcase then is bad. I may be better starting from scratch, eh? Sounds like a detective story. Not sure what happened. ( My maternal grand father is from Tromso, up north.)
UJ
11Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Fri Dec 28, 2012 7:41 pm
tioJaimito '85 K100rs wrote:It seems that my top case has a hole about 25mm in the bottom center. Perhaps this hole used to be smaller.
Once upon a time that hole have been 14mm, ....and part #3 is 18,5mm dia.
The only purpose for part #3 is to keep the pin in place, so you don't really need it
(just keep the pin inside the top case at all time).
The washer inside the top case is 40mm, so I wouldn't be that concerned about the bigger hole.....if the top case feels securely tight fixed against the carrier.
And Tromsø is far north Blizzard , I understand that your ma's grandpa did move over the pond.
1985 K100RT Parts Dzus_l10
12Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Sat Dec 29, 2012 10:03 am
tio Jaimito
tio Jaimito
thank you inga,
I will still look for the lower mount, which is missing. My mother's father, and mother Rasmus and Inga (Bockamo)Jensen came to chicago in 1917. For them it was like moving to the Mediterrenean I would imagine.
13Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Sat Dec 29, 2012 10:26 am
tioJaimito '85 K100rs wrote:thank you inga,
A bit fun with this old info, your grandmother got a nice name Razz ........by her surname,
I would guess she (or older relatives) have originated from Sweden.
During end of 1800's and early 1900 it was a lot of Norwegians that did emigrate to "over there" as it was very tough times in Norway with high unemployment rate.
14Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Sat Dec 29, 2012 10:36 am
tio Jaimito
tio Jaimito
Hi Inge (not Inga, sorry for my error), That was right, her side was originally from Sweden, half and half. Rasmus who was a shoemaker, began building homes on Chicago North Shore. He worked until he finally fell off a scaffold and broke his hip at 88 years of age. Both of them came from enormous families. My sister has gone over to meet some of the relatives. I must do the same. I also appologize to anyone who has to read this history, against their will. Embarassed
15Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Sat Dec 29, 2012 10:57 am
tioJaimito '85 K100rs wrote: Hi Inge (not Inga, sorry for my error),
That's OK, you're not the first one........got kind of used to it.
tioJaimito '85 K100rs wrote: I also appologize to anyone who has to read this history, against their will. Embarassed
We are a little bit off track 1985 K100RT Parts 652573 ......others don't have to read...
But I did enjoy this info, thanks. Very Happy
16Back to top Go down   1985 K100RT Parts Empty Side Covers on Sat Jan 12, 2013 10:58 pm
Raybo
Raybo
Do you still have the side covers?
Ray
17Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Sun Jan 13, 2013 1:12 pm
frogy
frogy
@Raybo wrote:Do you still have the side covers?
Ray
Yes I do.The L/S has the tab that slides into the pin attached to the bike broken off ,but I did not notice this until I started taking plastics off (it never moved).The R/S is fine. Color is dark green.$30 for left and $40 for right plus shipping.I can Email you pics
18Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Tue Mar 05, 2013 7:45 pm
frogy
frogy
Rack,top case sold. Still have side cases,radiator plastic cover,old brake hoses (rears replaced in 06 then bike sat.),side case mounts,glove gox cover,dash cover,ignition/switch pad (looks new),batt.covers left and right,frt fender,rear fender/license assembly,tail section,brake light,turn signals,speakers,speaker covers,and some fairing brackets.
19Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Tue Mar 12, 2013 12:33 pm
Shep
Shep
What is the asking price for the side cases? Are they black and are they in reasonable condition?
Shep
20Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Tue Mar 12, 2013 9:05 pm
frogy
frogy
They are in very good shape,and black.For both it would be $270.00 plus ship.They are this cheap due to this model does not use a locking cylinder and inner retaining straps are worn out from age.Hinges and clasps are in great shape.
It does not look like prior owner used these much.
21Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Sun Jun 23, 2013 10:47 am
frogy
frogy
Items still avail.
22Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Fri Dec 06, 2013 5:40 pm
frogy
frogy
Side cases sold.
23Back to top Go down   1985 K100RT Parts Empty Re: 1985 K100RT Parts on Sun Dec 08, 2013 5:21 pm
Brad-Man
Brad-Man
L&R Battery Covers still available?
What condition and how much?
Pics?
24Back to top Go down   1985 K100RT Parts Empty covers on Mon Dec 09, 2013 9:06 am
frogy
frogy
On my way to work and have Daddy Doos tonight. I can check items Tues. for you.
From memory no cracks in either, but I think L/S might have tab missing. It has been a year since I glanced at them. The color is a dark green.
25Back to top Go down   1985 K100RT Parts Empty covers on Tue Dec 10, 2013 8:50 am
frogy
frogy
OK, looked at covers. Left side is missing middle tab that slides on pin that is welded to frame. It has two little nicks that are not noticeable. R/S cove is like new,no blems and has all tabs.
$45 for L/S and $65 for R/S , plus shipping for both.
I can send pics if I have your email.
