puntolimitecero
puntolimitecero
Whit no sophisticated media, you can build by yourself a tester as useful as the original BMW one but much more cheaper.
Homemade multifunction ignition timing-ABS code reader-injectors tester 3152F7AEA13952B871233752B867F4
   Homemade multifunction ignition timing-ABS code reader-injectors tester 3052F7AEA03752B871213652B867F3
 You can make a simple and elementary one, that would be about this, that needs more wire and more and has two independent circuits, one of them fed with a 9 volt battery to test ignition and the other with no fed to read ABS codes, testing injectors signal,... all assembled into the same casing:
Homemade multifunction ignition timing-ABS code reader-injectors tester 2452F7ABFA2E52B86E753352B8654D
 Other resource, a bit more sophisticated but more simple on shape would be this other. A transistor is used as a switch to light the led diode when Hall sensors or ABS signal is present, depending on switch status.
   Homemade multifunction ignition timing-ABS code reader-injectors tester 2852F7ABFE3352B86E7A2E52B86551
    When switch is on, the circuit feds Hall sensor and receives signal from it when ignition point is reached. This signal polarizes the transistor, that connects the led diode to ground.
  When switch is off, the circuit dont send fed out to anything, it only feds the positive pole of led. When ABS or injectors signal is received, transistor polarizes and the led iluminates.
  Transistorized tester.
I have used an old tyre pressure tester case to hold in the circuit. I never throw away anything.
 Homemade multifunction ignition timing-ABS code reader-injectors tester 2D52F7AAD12C52B86D413352B86424
 Homemade multifunction ignition timing-ABS code reader-injectors tester 2F52F7AAD32F52B86D443552B86426
To complete the job and make it more professional, you can design some stickers with the operation explanation:
 Homemade multifunction ignition timing-ABS code reader-injectors tester 2D52F7AAEC2C52B86D653C52B8643F
 Homemade multifunction ignition timing-ABS code reader-injectors tester 3052F7AAD42852B86D463652B86427
  No transistor circuit
 For the more simple version, we can recycle a DC charger capable of hold the two circuits:
 Homemade multifunction ignition timing-ABS code reader-injectors tester 3052F7AAE62C52B86D5C3652B86439
 Homemade multifunction ignition timing-ABS code reader-injectors tester 3352F7AAE02E52B86D553952B86433
 Homemade multifunction ignition timing-ABS code reader-injectors tester 2C52F7AAC73352B86D363252B8641A
   You can use a original Hall sensors female harness to connect the tester with the harness on bike. Thus will made the operation easier.
 Saludos
Last edited by puntolimitecero on Tue May 06, 2014 6:17 pm; edited 1 time in total
Thanks for that I just might make one or at least shall put it on the end of a long list of gonna doos.
Homemade multifunction ignition timing-ABS code reader-injectors tester 112350
BIG D
BIG D
Cool
Brilliant stuff, my soldering iron will be coming out of retirement Very Happy
BIG D
japuentes
japuentes
Hi there.
Very nice and elegant solutions.
I´ll try them, but being a lego on electronic gadgets, I would like to know the resistance values and transistor type that could be used.
Best regards
JAP
Homemade multifunction ignition timing-ABS code reader-injectors tester 2854237993 1988 K100RS SE/ABS
puntolimitecero
puntolimitecero
You can use almost any transistor. I used a BCY70. The resistor value is about 470 to 1000 ohm.
Saludos
japuentes
japuentes
Excelente, muchas gracias !.
Un saludo
JAP
Images have disappeared from this thread.  Did anyone have the foresight to make copies of this before the images went missing?
puntolimitecero
puntolimitecero
Sorry, I had changed the image hosting server. Post edited.
   Saludos
Kafflut
Kafflut
I want to build the tester, but am very challenged when it comes to electronics. I need to match the wires in the first circuit diagram with the wires in the photo of the tester. I'm interested only in the ignition timing bit - ignore the ABS part. If one were to number the wires in the circuit diagram from left to right, 1 - 2 - 3 - 4, please match them with the red, green black wires in the photo.
Thank you
Paul
http://bmwk100k75.weebly.com/
The photo with the tester using the red-green-black wires is the transistorized tester and you are asking for information on the non-transistorized varient of the circuit. I presented the annotated photo on the non-transistorized unit based on your instructions.
  Homemade multifunction ignition timing-ABS code reader-injectors tester Austra12    Fuel:  95 Octane
puntolimitecero
puntolimitecero
@Kafflut wrote:I want to build the tester, but am very challenged when it comes to electronics. I need to match the wires in the first circuit diagram with the wires in the photo of the tester. I'm interested only in the ignition timing bit - ignore the ABS part. If one were to number the wires in the circuit diagram from left to right, 1 - 2 - 3 - 4, please match them with the red, green black wires in the photo.
Thank you
Paul
   Hi.
   Here you are the colors of the wires for the transistorized version.
   Homemade multifunction ignition timing-ABS code reader-injectors tester 2D562F9C171E55F05EEE2A55F0556A Homemade multifunction ignition timing-ABS code reader-injectors tester 3052F7AAD42852B86D463652B86427
   You must consider that you need to use the same green wire to check one Hall sensor and then change it to the other.
   Regards
Kafflut
Kafflut
Wonderful! I get it - this I can do. Thank you very much.
Paul
