1Back to top Go down   Right Hand switch block Empty Right Hand switch block on Thu Feb 21, 2013 8:06 am
larrikin
larrikin
Does anyone have a spare Right Hand switch block? Mine had the green cover come off Sad Sad
Right Hand switch block Au-log11 Right Hand switch block Au-log11
88 BMW K100RS
It increases my paranoia
Like lookin' at my mirror and seein' a police car
2Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Thu Feb 21, 2013 8:09 am
I may do....will look in the morning.....for a while there I went nuts with a busted switch block and relays etc etc etc
shall tell you tomorrow ok?...if I have, can see you at the Macquarie Arms on Sunday...
KKlompy Right Hand switch block 2854237993
Right Hand switch block Au-log10
3Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Thu Feb 21, 2013 3:25 pm
larrikin
larrikin
Thanks mate
88 BMW K100RS
4Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Thu Feb 21, 2013 7:50 pm
@Klompy the grey brick wrote:...if I have, can see you at the Macquarie Arms on Sunday...
Ahh, you guys in the UK and Down Under are so civilized. Pubs, camaraderie and all that I mean.Right Hand switch block 502531 No such cultural pursuits here in Ontario. Been ages since I "popped 'round to the pub with me mates".
5Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Thu Feb 21, 2013 10:23 pm
Larrikin,are you looking for a new cover for the green starter button?
Right Hand switch block P2220312
I had my cover come about 7 years ago on my naked. With the help of a self tapping screw, silicon and a cover button from a hardware store the problem was fixed.
Right Hand switch block P2220313
6Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Thu Feb 21, 2013 11:05 pm
ainsjac wrote:Larrikin,are you looking for a new cover for the green starter button?
Eye spy some good honest Dubbo dust on there Ainsjac.
Good to see you doing your part for the water shortage
7Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Thu Feb 21, 2013 11:46 pm
Yep....at one stage they were selling jars of Dubbo Dust to international tourists and visitors from Castle Hill..
8Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 2:07 am
Yo Larrikin as luck would have it I have 2 LH units having given Tackler a RH unit cause he needed one to get back to QLD...will have a look on Sunday with you and see if we can fix something till you can source a part.....I am sure someone would have an ice cream container full of Beemer lectrics....8.30 am at the Macquarie Arms they make a great breakfast at the Cafe across the road....nice folk too.
9Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 5:36 am
Larrikin, did you manage to salvage the spring when it popped.
Mine on the LT popped 3 hours from home, spare tape on board, wrapped around the grip a few times, got me home. Was a bugger on the throttle though (letting off). Once home took the spare button from the RT, still working well.
Good work ainsjac, what did you attach the screw to, was the green button still in place?
1987 K100RT  Ex- police
1989 K100LT  Ol' Blue and "Kart" the Kamper trailer.  now KAPUT .
Right Hand switch block 10_x_110
10Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 6:14 am
I might have one in the shed. Will have a look when it stops pi&*ing down...whenever that might be.
11Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 8:09 am
Sean you should be able to go see on Monday remember what they say? What do you get after two days of torrential rain??? A Monday Shocked
12Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 8:59 am
larrikin
larrikin
It was the green cover that popped off. Mick Dyer had look and said it would need replacing.
So the easiest way to do it is replace the whole thing
Klompy we could be next door the the Macquarie Arms.
88 BMW K100RS
13Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 9:17 am
14Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 12:19 pm
UK e-bays switch clusters go for about £20. I bid on a pair this week (just because they had colour in the buttons), but missed out, sold for:- LH £12.50, RH £18.
15Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 5:09 pm
Grover, I had just got the old girl through the rego check....went to start it and it kept "running on" so I went to lift the button up. Well it became so fragile it just fell off........watch for spring. I used a thin self tapper after I got a quote for a replacement (ouch). Silicon to make sure I wasn't shorting things and also to "glue" the new cap on. Oh, I think I may have use a washer as well.
16Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 6:23 pm
are the green buttons available just on their own , I didn't see any on motobins?
ingenious effort Stan, well done.
17Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 10:48 pm
Come on Stan...sort yourself out!
Black starter buttons are up there with white zip ties!
Paint the damned thing green! Laughing
18Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 11:25 pm
Doh! The spare one I have is not too flash either!
Right Hand switch block Sam_2413
19Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Fri Feb 22, 2013 11:52 pm
still wet outside Sean?
bucket loads here.
20Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Sat Feb 23, 2013 12:13 am
Just managed to sneak out to the shed and then take the dog for a wander...so it's easing off a bit. Smile
21Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Sat Feb 23, 2013 2:02 am
I am so sorry Blakey. I had a choice of white or black at the time. I do have some ORANGE paint though. Next time I have the spray booth I will paint the button.
22Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Sun Feb 24, 2013 1:27 pm
groverK wrote:are the green buttons available just on their own , I didn't see any on motobins?
It's plenty available, you've been searching at the wrong place.
Right Hand switch block Gumdro10
23Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Sun Feb 24, 2013 1:28 pm
Right Hand switch block 44271
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%ORight Hand switch block Au-log10
24Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Sun Feb 24, 2013 4:15 pm
Inge, those buttons are special ones for Sundays.......they are holey.
25Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Sun Feb 24, 2013 4:16 pm
Right Hand switch block Botton
Last edited by Klompy the grey brick on Sun Feb 24, 2013 10:03 pm; edited 1 time in total
26Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Sun Feb 24, 2013 8:01 pm
Oh decisions decisions do I use 2 hole or 4 hole buttons. Inge you crack me right up Right Hand switch block 44271
27Back to top Go down   Right Hand switch block Empty Re: Right Hand switch block on Sun Feb 24, 2013 9:01 pm
They are very cheap and I am sure you have one somewhere in your house Smile
Right Hand switch block Green_10
Right Hand switch block Frog15Right Hand switch block Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
