1Back to top Go down   '91 K100rs in reno $1200 Empty '91 K100rs in reno $1200 on Fri Feb 22, 2013 7:49 pm
JimK
JimK
Dang! $1200!!!
http://reno.craigslist.org/mcy/3588584111.html
Nevada,USA.
Arrgh!
Wish was closer.
Last edited by JimK on Fri Feb 22, 2013 7:51 pm; edited 1 time in total (Reason for editing : clarity)
'89 k100 rs se
2Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Sat Feb 23, 2013 1:20 am
Themason
Themason
Mad That thing is rough. Let it go. You'de be out many many thousands making it look like something.
Did you notice the orange V-Rod behind it?
1986 R-80G/S w/1000 cc engine
3Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Sat Feb 23, 2013 2:52 am
Yes but I ignored it Smile
4Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Sat Feb 23, 2013 5:05 pm
frogy
frogy
Take it home,part out the plastics,and cases.Then turn it into a Naked.
Im doing that with mine.
5Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Sat Feb 23, 2013 6:38 pm
obviously has his priorities wrong , should be parting with the Hardley's.
1987 K100RT  Ex- police
1989 K100LT  Ol' Blue and "Kart" the Kamper trailer.  now KAPUT .
'91 K100rs in reno $1200 10_x_110
6Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Sat Feb 23, 2013 6:41 pm
frogy
frogy
groverK wrote:obviously has his priorities wrong , should be parting with the Hardley's.
Hey wait a minute theres not That much chrome on the K:suspect:
7Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Mon Feb 25, 2013 11:24 pm
JimK
JimK
@Themason wrote:Mad That thing is rough. Let it go. You'de be out many many thousands making it look like something.
Thanks for your.......input?.
Looked/looks like might be good for making something of it.
Fellow might have side panels.
Dunno.
Kinda sharp response. Am trying to figure out the comment of where "many, many thousands" is accurate.
I don't believe that. Do you know this bike? 41k miles on the same.
You call the fellow?
What's with the shooting from the hip, on the matter?
Seems to me that this offering for $1200 for a 16v could be a good thing for one of our crowd.
JimK
Last edited by JimK on Mon Feb 25, 2013 11:36 pm; edited 3 times in total (Reason for editing : I wasn't finished yet...still may not be :))
'89 k100 rs se
8Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Mon Feb 25, 2013 11:29 pm
club_c
club_c
Bad starter... brushes? Oh that would be a lovely cheap fix to get it on the road!
1988 K100RS SE VIN 01477554
9Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Mon Feb 25, 2013 11:46 pm
Couple of grand each for starter brushes could make it expensive Smile
10Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Tue Feb 26, 2013 12:03 am
JimK
JimK
Just texted seller.
Sent back Sold.
Just spoke with seller.
Said fellow named Tim bought it.
FWIW.
JimK....
'89 k100 rs se
11Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Tue Feb 26, 2013 1:52 am
Themason
Themason
Paint is at least $1500 on an RS. Minimum. And that is just the bodywork. Refinishing wheels and ancilaries will cost all that much more. 40K means time for a spline lube. How do the Paralever bushings feel? Does it need a rear main seal or a clutch? How are the brakes? Is the front master cylinder leaking? Pretty common feature of that style master cylinder and not a lot of fun nor are they cheap to rebuild. Does it need head bearings? Betcha it does, and fork seals too. How about a stainless steel fastener kit or replating the original fasteners with cad or bright nickel? Then there are some expensive rubber and plastic parts. I can almost guarantee the stock exhaust is cracked at the welds between the headers and the collector. Again, that is a pretty normal fault of that exhaust unless the owner did something to prevent it (welding small rods between headers about 25 mm up from the collector seems to take the vibration that cracks them) AND was very diligent about keeping all the rubber mounting points fresh. Judging from the appearance, I am certain the owner did not and you have a broken exhaust that will be expensive to replace, if you can find one that is not cracked. Good luck. I'v restored some K-RSs and know what they cost. I am in the middle of an RT/LT frankenbike project using nothing but used parts and I figure I will be lucky to get out for under six grand. That thing won't be cheap to make nice.
12Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Tue Feb 26, 2013 2:18 am
Themason you are the one who said "making it nice" no one else said anything about even making it roadworthy.
The bike was simply pointed out by Jim K and you bounced in saying don't touch it.
Paint who said paint only you it doesn't have to have paint to ride it. The wheels look fine and are round with tyres and air.
How the hell do you know what needs doing the owner may have looked after it quite well and just having 40k on it does not mean that it has to have a spline lube done, the owner may have just done it you don't damn well know any off that you are making wild asumptions with no backing at all.
13Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Tue Feb 26, 2013 9:26 pm
tio Jaimito
tio Jaimito
@Rick G wrote:Themason you are the one who said "making it nice" no one else said anything about even making it roadworthy.
We all have a little Curmudgeon in us, from time to time. 🤡
Krazy Kat. 1985 K100RS Alaskablau 13000miles 8valve "Black Belly"
Peggy's 1987 K75s Columbia Grey 9500miles 6 valve.
'91 K100rs in reno $1200 K100_m12
'91 K100rs in reno $1200 K75_po12
'91 K100rs in reno $1200 Basil_10
http://www.nachicagonorth.com
14Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Tue Feb 26, 2013 10:37 pm
certainly seen a lot worse looking at a much higher price...in OZ at any rate..I guess its all part of the fun..it could be perfect or an absolute piece of Sh%T...THATS THE FUN PART FINDING OUT.
'91 K100rs in reno $1200 3E33Ka3J45E35K25J9d22bd7a154afaa615d7
KKlompy '91 K100rs in reno $1200 2854237993
'91 K100rs in reno $1200 Au-log10
15Back to top Go down   '91 K100rs in reno $1200 Empty Re: '91 K100rs in reno $1200 on Wed Feb 27, 2013 6:33 pm
Themason
Themason
Look at it. We know the starter is inop because the add tells you so. It says it runs ok after you push start it. K100 starters do not often fail. What else is wrong with it? No battery covers, damage pretty much to every corner of the body work. Sun faded. That thing has been neglected. Look, I worked at two bike shops including a BMW franchise. This isn't my first encounter with one of these. I would be amazed not to find a lot of time consuming and expensive "deferred" maintenance on that bike. I also know that even well maintained 16V bikes have exhaust system cracks. I had exactly that bike in the same color, and BMW replaced six exhausts under warranty when the welds connecting the headers to the collector failed. There is a way to reinforce them so they do not crack but I would be very surprised to find that mod on that bike. Finding a replacement exhaust takes time and $s. I know my way around these bikes pretty well.
