1Back to top Go down   7,700kms 85RS Gold Coast Empty 7,700kms 85RS Gold Coast on Mon Mar 25, 2013 10:54 pm
RS
Might be a new Australian record for low kms.
Price is too high regardless and the photos are crap. Couldn't he stand a bit closer with the camera?
Still, if anyone is in the area might be worth a look just to see how nice (or crap) it really is.
rossco
2Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Mon Mar 25, 2013 11:19 pm
If he reversed the 6 & 3 he would come closer to the right price. A bike of that age with so low Ks would probably need the seals replaced. If they aren't leaking now they will soon.
3Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Tue Mar 26, 2013 12:37 am
73MOH
73MOH
Is that fuel level indicator correct for a 1985 model? as in 7L and 4L warning lights.
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
4Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Tue Mar 26, 2013 12:40 am
@73MOH wrote:Is that fuel level indicator correct for a 1985 model? as in 7L and 4L warning lights.
April 85 was the change date
5Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Tue Mar 26, 2013 2:26 am
notice the rear disc is aftermarket...would not think 7700 kms would wear one out....I guess a bike is only as old as the clocks say...
KKlompy 7,700kms 85RS Gold Coast 2854237993
7,700kms 85RS Gold Coast Au-log10
6Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Tue Mar 26, 2013 2:49 am
Uh Oh. Is Rossco planning another trip to Queensland?
Can you leave the rain behind this time. 7,700kms 85RS Gold Coast 178468
7Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Tue Mar 26, 2013 3:28 am
I aint even leaving home Very Happy
8Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Tue Mar 26, 2013 4:04 am
Well there is a long weekend coming up affraid
9Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Tue Mar 26, 2013 5:50 am
I went about looking for some very low mile K100s. I got some advice from someone who knows them reasonably well....
Seals even though ok for now, unlikely to last, especially crankshaft end seals.
Oil/water pump.
ABS failure [if an ABS bike] due to non changing of brake fluids, also brake caliper piston seizure/seals. Rear master cylinder replace seals.
6/12 rivet issue but need to check date.
Seals in final drive.
Spline lube.
Replace fuel pump, filters, high pressure fuel lines to injector rail. Check for corrosion inside petrol tank.
Check for valves/unleaded petrol, some earlier ones need head work done to run on unleaded petrol.
If bike was parked up and left for years on end without being run you can get a tight spot on the timing chain. Tensioner also can fail.
Coolant sysem hoses may be perished. Also a risk of internal corrosion if simply laid up with water and no corrosion inhibitor. Replace hoses and thermostat.
New tyres, old ones will either perish or have flat spot from being parked on them. 5 year age limit.
He recommended the above items be done as a minimum and treat as a new bike and run in gently. I know he was being a small bit fussy but I have been around laid up motorbikes for years and its quite amazing what fails through lack of use as opposed to normal use or even neglect. A certain amount depends on whether the bike was 'prepared' for being laid up. All in all a budget not to be ignored but would result in a seriously good K!!
1997 K1100LT 0188024 Wotan Mystic Red 689 58,645 now 102,500 miles
1983 K100RS 0011171 Fricka 606 29,495 miles Damn K Pox Its a Bat outta Hell Now 36,188  miles
10Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Wed Mar 27, 2013 12:12 am
Sent the guy an email asking for better pics.
Said he would post some and is looking at around $5000.
Much better price, but still want to see it close up. And check that rear disc for Mr Klompy
11Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Wed Mar 27, 2013 1:17 am
I sent an email asking for the numbers and no reply so maybe it's not what he claims.
12Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Wed Mar 27, 2013 1:27 am
tell him "hes dreaming "
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%O7,700kms 85RS Gold Coast Au-log10
13Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Wed Mar 27, 2013 1:55 am
AuntieBB
AuntieBB
This LT looks tempting though. linky-dink
once upon a time: 1987 K100RT/TIC
now: 2010 R1200GS
14Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Wed Mar 27, 2013 4:15 am
indeed aunty ..
15Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Wed Mar 27, 2013 7:19 am
Somebody better check the airports , Rossco could be loose.
BB, are you sure it's not 88 doing a surprise Australian tour, surely he would have phoned first.
1987 K100RT  Ex- police
1989 K100LT  Ol' Blue and "Kart" the Kamper trailer.  now KAPUT .
7,700kms 85RS Gold Coast 10_x_110
16Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Thu Mar 28, 2013 1:03 am
Themason
Themason
[quote="Klompy the grey brick"]notice the rear disc is aftermarket...would not think 7700 kms would wear one out....I guess a bike is only as old as the clocks say...[/quote]
Very early production K100s came with a rear disc slotted exactly like the front disc. This was discontinued because the rears for some reason would curl like a potatoe chip, er potato crisp for you Aussies. That is actually a very rare rear disc. [i]Really[/i] early production K100s even had a little drain plug in the lower rear corner of the valve cover. You can see the round boss in the casting of all the K100 valve covers where the drain plug was machined.
If you look carefully you can see both features in this photo taken from original BMW sales literature.
[url=http://www.motorcyclespecs.co.za/Gallery/BMW%20K100RS%2083.jpg]http://www.motorcyclespecs.co.za/Gallery/BMW%20K100RS%2083.jpg[/url]
The bike also has the passenger grab strap on the seat, another tell-tale early production feature discontinued during the 1984 model run.
1986 R-80G/S w/1000 cc engine
17Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Thu Mar 28, 2013 3:17 am
73MOH
73MOH
@Themason wrote:
@Klompy the grey brick wrote:notice the rear disc is aftermarket...would not think 7700 kms would wear one out....I guess a bike is only as old as the clocks say...
Very early production K100s came with a rear disc slotted exactly like the front disc. This was discontinued because the rears for some reason would curl like a potatoe chip, er potato crisp for you Aussies. That is actually a very rare rear disc. Really early production K100s even had a little drain plug in the lower rear corner of the valve cover. You can see the round boss in the casting of all the K100 valve covers where the drain plug was machined.
Aussies say chips.. Your confusing us with the english...
My 86 has the strap on the seat.
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
18Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Thu Mar 28, 2013 5:10 am
mine is an 84RS and the very plain rear disc which is the same as Rossco's 86.etc etc etc...
19Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Thu Mar 28, 2013 6:38 am
groverK wrote:Somebody better check the airports , Rossco could be loose.
Rest easy Grover - I was turned back at immigration. I told them in my best Irish Brogue I wanted a job as a "pile it"!
but when they interviewed me and discovered I couldn't fly, I just wanted a job stacking boxes, they threw me out Shocked
lol!
7,700kms 85RS Gold Coast Ir-log11 88....May contain nuts!7,700kms 85RS Gold Coast Ir-log11
20Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Fri Mar 29, 2013 12:01 am
Halo
Halo
His right mine has the drain plug on my early rs
84 K100RS 0014803
93 FZR1000 EXUP
21Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Sat Mar 30, 2013 2:10 am
Themason
Themason
[quote="Klompy the grey brick"]mine is an 84RS and the very plain rear disc which is the same as Rossco's 86.etc etc etc...[/quote]
So does my '84 manufactured in July, but you can see photos of really early production K bikes with slotted rear rotors. That style of rotor was discontinued very early in production due to warpage problems.
22Back to top Go down   7,700kms 85RS Gold Coast Empty Re: 7,700kms 85RS Gold Coast on Sat Mar 30, 2013 3:24 am
The K1100s have that slotted disc on the rear so they went back to a disc that had known problems. Hmmmm
