1Back to top Go down    RAM mounts on Sun Apr 21, 2013 4:21 pm
DeRodster
Greetings all,
Just wonder if the RAM Mount ball mount for the mirror RAM-B-236U mounting hole on the left hand side handle bar is going to fit.
ie is that hole threaded.....?
I know you are asking ''why doesn't he go out and look'''....thing is I'm not near the machine just now and i want to order a suitable mount for gps.
ta
Rod
1992 K1100LT 6455194, 1943 BSA WM20.
2Back to top Go down    Re: RAM mounts on Sun Apr 21, 2013 6:19 pm
Rod,
The mirror holes are not threaded; 8mm clearance and 28mm deep.
Cheers,
Paul
3Back to top Go down    Re: RAM mounts on Mon Apr 22, 2013 3:25 am
DeRodster
Thanks Paul
Just as well I checked first.
Rod
4Back to top Go down    Re: RAM mounts on Mon Apr 22, 2013 3:54 am
Rod have a look at some of the posts on here where they have fitted a ram mount.
One common route is to drill a hole through an unused switch on the dash, stick the threaded bar through the hole and put a small plate and nut on the bottom.
All the damage you have done is to the switch blank.
Basic/2 6308802K100CJ05/1988
5Back to top Go down    Re: RAM mounts on Mon Apr 22, 2013 6:07 am
DeRodster
Will do
Ta
R
6Back to top Go down    Re: RAM mounts on Mon Apr 22, 2013 8:58 am
KKlompy
