1Back to top Go down   want to get one of these Empty want to get one of these on Thu May 23, 2013 9:38 am
Hi all would like one of these top box leveller racks if anyone has one lying around or knows where to get one...thanks to bolt for the piccy
want to get one of these Rack_b11
KKlompy want to get one of these 2854237993
want to get one of these Au-log10
2Back to top Go down   want to get one of these Empty Re: want to get one of these on Thu May 23, 2013 3:36 pm
Avenger GT
Avenger GT
That's a Givi rack Klompy. I made my own out of a length of 10mm reinforcing bar, welded to 4 bits cut from a Hillman Avenger steering shaft, drilled and tapped, and cut at an angle to fit the tail of the bike. Two bits of flat welded between them, and the Givi mounting plate bolted to those. The rubbers between the mounting posts and the tail piece are tap washers. Mind you you could probably buy one cheaper than the time it took to make it, but I was having a slow day and fancied something to do.
want to get one of these Rack211
want to get one of these Rack311
3Back to top Go down   want to get one of these Empty Re: want to get one of these on Thu May 23, 2013 4:32 pm
You don't have to be too fancy.
4 straight posts cut at the right angle will do the job.
want to get one of these Posts10
want to get one of these Frog15want to get one of these Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   want to get one of these Empty Re: want to get one of these on Thu May 23, 2013 4:40 pm
73MOH
73MOH
I got one a couple of years ago from the bm shop... reasonably priced considering.
Paul
1986 K100 RS
1997 K1100LT
2005 KTM990sd
5Back to top Go down   want to get one of these Empty Re: want to get one of these on Thu May 23, 2013 8:21 pm
Halo
Halo
Haha Mr Klompy needs one because his rack is always pulling monos at present
84 K100RS 0014803
93 FZR1000 EXUP
6Back to top Go down   want to get one of these Empty Re: want to get one of these on Fri May 24, 2013 1:55 am
Given I reach such high speeds the airflow across what is now considered to be an elevated airfoil gives the back of the bike added lift....more than compensating for the weight of my arse...the only other alternative is to mono the front of the bike but I am unsure how long I can keep that up.... Very Happy
want to get one of these Pic194
7Back to top Go down   want to get one of these Empty Re: want to get one of these on Fri May 24, 2013 4:37 am
bolts
bolts
Klompy, Not sure if you got my PM or indeed if I sent it, but I got my rack at :-
Discount Motorcycle Wreckers
Ph +61 03 9350 4417
Fax +61 03 9354 1933
35 Dawson St, North Coburg
Victoria 3058, Australia
1985 K100RT, VIN 0029031
1985 K100RS, VIN 0083583
1973 Honda CB750
1948 AJS 500
All on club plates
8Back to top Go down   want to get one of these Empty Re: want to get one of these on Fri May 24, 2013 7:24 am
thanks bud but no joy at Coburg.....
9Back to top Go down   want to get one of these Empty Re: want to get one of these on Mon Jun 03, 2013 5:28 am
the.postman
There's one on eBay now. It's in France and it says will post worldwide
Here
1984 srx 600
1986 cbr1000f/h
