1Back to top Go down   Sticky transmission Empty Sticky transmission Thu Jun 13, 2013 12:36 pm
otto59
1985 K100. Jumps out of second gear and won't shift higher than second. Time to check the clutch spline lube?
2Back to top Go down   Sticky transmission Empty Well Thu Jun 13, 2013 12:49 pm
ibjman
ibjman
Well, You'll be removing the transmission to repair it, so you can lube the clutch while it's out.
I suspect you need trans repairs. The good news is that there are a lot of good used transmissions out there for very reasonable money. So In My Opinion, it makes better sense to exchange it rather than repair it.
Regards, Ibj....
3Back to top Go down   Sticky transmission Empty Sticky transmission Thu Jun 13, 2013 5:27 pm
otto59
ibjman wrote:Well, You'll be removing the transmission to repair it, so you can lube the clutch while it's out.
Regards, Ibj....
But is transmission really faulty?  You don't replace the fuel tank just because the cap is faulty, do you?  Seems everything points to clutch spline lube by some of the shifting problem posts here.  Anyone else have any ideas?
4Back to top Go down   Sticky transmission Empty We don't know yet, but Thu Jun 13, 2013 6:13 pm
ibjman
ibjman
After engaging 1st & starting away......it should be possible to shift up through gears even with the clutch fully engaged (even if a little herky-jerky), by backing off the throttle slightly at the shift points between gears. The fact that it won't go above 2ond at any time, coupled with the fact that it pops out of second........sounds like more than just a clutch problem.
Maybe someone else on the forum will follow with a more desirable opinion.
I really hope that I am incorrect.
Also with the bike on the center stand and the engine off you should be able to shift through all 5 gears up & down, by jogging the back tire back & forth slightly as you lean on the shift pedal with your hand.
Regards, Ibj..
5Back to top Go down   Sticky transmission Empty Re: Sticky transmission Thu Jun 13, 2013 8:40 pm
Ghost who rides
Ghost who rides
I agree with ibj s comments . We have seen here where the shift lever clamp bolt was fouling on a non standard exhaust . This would be your only chance of an external fix AFIK . Agree better to buy a sh box then fix the old one at your leisure . Good luck with it , G
6Back to top Go down   Sticky transmission Empty Re: Sticky transmission Thu Jun 13, 2013 9:10 pm
Totally agree, if you are having problems shifting up and down then suspect the splines but cant shift past 2nd then you have gearbox problems.  Has the shift lever got a lot of slack as you may have trouble with the shift mechanism. There is a small grub screw that can work lose and will sometimes cause the problem but more often it prevents any changes.
As ibj said you are going to have to pull the gearbox out for repair or replace but whatever you do dont throw the old one away they are needed for spares by others.
7Back to top Go down   Sticky transmission Empty Sticky transmission Fri Jun 14, 2013 11:53 am
otto59
Looks like its time for a newer bike. Will part the old girl out
8Back to top Go down   Sticky transmission Empty Part out? Fri Jun 14, 2013 12:02 pm
ibjman
ibjman
I recently sold a transmission for 1 of these  for $25. Are you sure you want to part it out????
9Back to top Go down   Sticky transmission Empty If you do Fri Jun 14, 2013 12:15 pm
ibjman
ibjman
If you do decide to part it out......I too have one of those "paper thin" rear rotors you spoke of. I had a just like new one that I sold for $40 and now I'm kicking myself BIG TIME.
Pleas give me an option on that almost new one that your recently installed.
 I could really use a deal on one.
Thanks, Ibj...
10Back to top Go down   Sticky transmission Empty Sticky transmission Sun Jun 16, 2013 1:00 pm
otto59
How do you know I have an almost new brake rotor?
11Back to top Go down   Sticky transmission Empty How did I know? Sun Jun 16, 2013 4:16 pm
ibjman
ibjman
I read back through your posts
12Back to top Go down   Sticky transmission Empty Sticky transmission Sun Jun 16, 2013 4:35 pm
otto59
A forum voyeur!  Anyhow, drained the gearbox and only found 2 very small metal flakes stuck to the drain plug. Fluid filtered out clean and didn't feel any grit in it.  Gearbox still pooched? Plus all the other stuff I find worn out.  There's a 96 K1100lt in Minnesota I'd like to look at.  Considered a K1200LT (my buddy bought one) but the final drive and hydraulic clutch servo failures are scaring me away.  The K1100 seems to be a happy medium.  I'll give you first crack at the rotor at a "reasonable" price.  Remember shipping and hassle increase tenfold the minute it crosses that border.
13Back to top Go down   Sticky transmission Empty Someone said Sun Jun 16, 2013 4:53 pm
ibjman
ibjman
I believe someone said that it's possible that your problem results from a loose grub screw on the inner end of the gearshift lever shaft???? Perhaps. That would be a reasonably easy fix, maybe. Probably would entail a new shift lever shaft and the end screw + perhaps the part on the end of the shaft that the screw actually secures to the shaft.
It would certainly be worth taking the cover off for an assessment when you take the tran. out.
 I believe I mentioned testing to see if you could move the trans into other gears while sitting idle (not running)  by jogging the rear wheel slightly for & back while operating the shift lever with your hand???
Did you try that?
As for the rotor....it looks like it would cost at least $41 to mail it from here to there......I wonder if it goes the opposite way for the same money?
 If I were shipping it anywhere in the usa.....it would be about $15.
I don't know where in CA you are located. Any chance you come south of the border now & again for any other reason?
Anyway. we will see as time goes on.
Thanks for the consideration at least.
Regards, ibj...
14Back to top Go down   Sticky transmission Empty Sticky transmission Sun Jun 16, 2013 5:32 pm
otto59
I'm in Winnipeg and 60 miles from the border. I cross frequently to pick up stuff.  I don't like being ripped off by customs brokers, it's usually cheaper to drive down and pay the taxes and duty, and then it's still cheaper than buying here!
15Back to top Go down   Sticky transmission Empty Any Sun Jun 16, 2013 6:01 pm
ibjman
ibjman
Any possibility if we can get a deal on this rotor (if/when you might be ready) that we can get you to mail it from the south side Us post office?
Actually, I think I could ship it from your home on my personal FedEx employee account for $26.
16Back to top Go down   Sticky transmission Empty Sticky transmission Sun Jun 16, 2013 11:55 pm
otto59
A new one from EBC is only $225
17Back to top Go down   Sticky transmission Empty I Mon Jun 17, 2013 12:33 am
ibjman
ibjman
I know.....that's a lot of money for me
18Back to top Go down   Sticky transmission Empty Rear rotor Thu Jun 20, 2013 11:55 am
otto59
Theres one on fleabay for $49.95 free shipping USA. I'm going to pull my gearbox in the meantime and search for a k1100lt or R1100lt.
19Back to top Go down   Sticky transmission Empty didn't see the one on flebay Thu Jun 20, 2013 5:19 pm
ibjman
ibjman
Didn't see the one on Flebay for 50?
20Back to top Go down   Sticky transmission Empty brake rotor Thu Jun 20, 2013 7:13 pm
otto59
pm'd you the item #
