1Back to top Go down   Fork snap-ring Empty Fork snap-ring Sun Jun 09, 2013 9:47 am
hitmanh
How do you remove the blimming fork snap-ring? Nothing to grip on to, to shift the bugger...
Matt
Fork snap-ring 8157
2Back to top Go down   Fork snap-ring Empty Re: Fork snap-ring Sun Jun 09, 2013 3:53 pm
The one above the fork seal? ...I'm using two small screwdrivers,
one of them grinded to a wedge shape at the tip.
3Back to top Go down   Fork snap-ring Empty Re: Fork snap-ring Sun Jun 09, 2013 4:51 pm
hitmanh
Yes, the one about the seal. Struggling to get at it, even with a fine jewellers screw driver, though, I'm being a bit paranoid about slipping and scratching the the slider. Will have another go tomorrow.
Fork snap-ring 8157
4Back to top Go down   Fork snap-ring Empty Re: Fork snap-ring Sun Jun 09, 2013 5:05 pm
Some patience is also needed when dealing with these buggers.
Everytime I have to remove some of these, I learn a few new words.
5Back to top Go down   Fork snap-ring Empty Re: Fork snap-ring Mon Jun 10, 2013 2:40 am
JR_K100RS
JR_K100RS
G'day hitmanh , yeah a bit of practice is required for these little buggers , what I usually do is to push the fork seal down out of the way with a piece of wooden dowel then using your free hand carefully lever the ring out of the groove with a jewellers screw driver , leave the screwdriver there then with a fine pair of needle nose pliers grab hold of the ring and pull it clear , this can be easier if you have an able bodied assistant to push the seal down , oh forgot to mention , I've only ever done it with the fork tube out of the bike held firmly in a vice ( use soft jaws ! )
good luck !
JR
Melbourne Australia
6Back to top Go down   Fork snap-ring Empty Re: Fork snap-ring Mon Jun 10, 2013 3:27 am
MikeP
MikeP
The problems I've encountered are where an old snap-ring has been re-used. Nothing wrong with that as long as the end hasn't been damaged making it difficult to get leverage.
I find that clamping the ring inside the slider with mole-grips helps. Needle nose grips and a rag to prevent damage, clamped opposite the open side of the snap-ring will stop it sliding inside the recess and it will pull the ring over slightly to allow you to get a hook under the end.
Replace them with new once you have them out. You'll be glad that you did the next time you have to do the job.
7Back to top Go down   Fork snap-ring Empty Re: Fork snap-ring Mon Jun 10, 2013 4:11 pm
hitmanh
Thanks all, got them out eventually, just took a bit of patience and a smaller jewellers screwdriver. I'm going to replace the snap-rings as there is some rusting, the dust covers obviously need replacing, the amount of gritty crud where the really the snap-rings sat cannot have done the seals any good. Next job is strip down the forks, clean them up and new springs to install.
Thanks!
Matt
Fork snap-ring 8157
8Back to top Go down   Fork snap-ring Empty Re: Fork snap-ring Thu Jul 11, 2013 4:14 am
Patto89
Patto89
Hi I am also having trouble removing Fork snap ring, can not get it to budge ! could it be Rusted on ?
9Back to top Go down   Fork snap-ring Empty Re: Fork snap-ring Thu Jul 11, 2013 5:10 am
I doubt it would be rusted on but they can be real buggers to budge. I ended up making a small cheap screwdriver into a sort of chisle point with a bend and finally got it to get under the ring.
I was getting to the stage of experimenting with fire to see if it would come, if you can get a second person to hold the cap down it helps a lot.
10Back to top Go down   Fork snap-ring Empty Re: Fork snap-ring Thu Jul 11, 2013 5:56 am
Patto89
Patto89
Thanks Rick, Will give it a try
11Back to top Go down   Fork snap-ring Empty Re: Fork snap-ring Thu Jul 11, 2013 6:38 am
Albyalbatross1
Albyalbatross1
I use a small bearing puller to hold the cap down. then gently pry the clip out.
