1 Speedometer bench testing Sat Jul 20, 2013 12:32 am
hotpuppy
I had a gear go bad on the odometer. Took it apart after reading various posts and articles. Only one gear appeared to be damaged/deteriorated, so I replaced just that gear. Unfortunately, in the process of taking the bad gear out I decided that the speedo face had to be removed. I now need to put the needle back on and I'd like to calibrate the speedometer with Karamba.
I need to know which pins do what on the back of the speedo. I reassembled it with the needle pointing to zero... not sure if that will be right or not. Has anyone else had to remove the needle and put it back? Is there a special procedure or process for this (it's a BMW after all)?
I've seen posts elsewhere that suggest I should find
12v+
sensor in
sensor out (wtf? really?)
ground.
I'm just not sure which direction is which and don't want to gamble or disassemble it far enough to get the board out for examination.
I really think it's +, sens, ground after looking at the connector.
and here's how I hold the speedo assembly... a $28 vise from Amazon....
12v+
sensor in
ground.
