1Back to top Go down   K100 dash light when ignition turned on Empty K100 dash light when ignition turned on on Tue Jul 23, 2013 8:51 am
OZhoppo
OZhoppo
I have been checking the K100 to make sure it is all good for roadworthy inspection.
When I turn on the ignition I get the usual flashing ABS warning light (which I know goes out once you move off) but I also get the triangle warning light flashing in sequence with the ABS warning light.  Is this normal ?
I know the rear brake switch is faulty and am buying a new one.... would that be the cause of the warning light or do both lights extinguish when moving and the brakes are dabbed ?
Have to activate both front and rear brakes to extinguish the warning light.
OZhoppo
OZhoppo
Thanks mate,
Fitted a new rear brake switch then took the bike for a short spin, applied both brakes and all lights extinguished.
