1Back to top Go down   Removing the battery Empty Removing the battery Wed Jul 24, 2013 12:46 pm
japuentes
japuentes
Hi there, regarding the matter subject I have a question for the group,   I´ve been removing the battery without disconnecting the injection module based on the principle of " don´t doing anything electrical without disconnecting the battery´s negative first ". This of course makes the job a little more difficult, but , reading some manuals, I´ve found that the procedure indicates to disconnect the FI module in order to reach the battery, so you´ll be disconnecting the  module before taking out the battery´s negative.
Is there an error on the procedure or in my interpretation? or  Have  I been  to much conservative?.
I´ll appreciate your kind answers.
Best regards
JAP
Removing the battery 2854237993 1988 K100RS SE/ABS
2Back to top Go down   Removing the battery Empty Re: Removing the battery Wed Jul 24, 2013 1:19 pm
brickrider
brickrider
I for one wouldn't put myself through the hassle of removing the battery with the computer and related stuff still in place on top of the battery.
The cable connection on the computer detaches easily, and during the procedure you can examine the contacts to verify there is no corrosion or other problems that may threaten reliability down the road.
Do pay attention to the release mechanism under the tool tray, otherwise, you're in for a frustrating time removing the computer.
3Back to top Go down   Removing the battery Empty Re: Removing the battery Wed Jul 24, 2013 4:47 pm
MikeP
MikeP
If you want to disconnect the battery before disturbing the Jetronic (and it's the simplest way to disconnect the battery when doing any work), just disconnect the main earth on the gearbox (arrowed):
Removing the battery BMW%20K75S%20%28243%29-L
I keep a piece of old inner tube handy and slip it over the connector to prevent accidental contact.
4Back to top Go down   Removing the battery Empty Re: Removing the battery Wed Jul 24, 2013 5:09 pm
MikeP is your bike really that clean? You make me feel guilty!
5Back to top Go down   Removing the battery Empty Re: Removing the battery Wed Jul 24, 2013 5:31 pm
MikeP
MikeP
That's my nephew's, mine is cleaner. Wink
6Back to top Go down   Removing the battery Empty Re: Removing the battery Wed Jul 24, 2013 7:03 pm
JR_K100RS
JR_K100RS
G'day Mike , would you mind if a lent you my bike for a bit , oh and if you felt like cleaning it feel free !
JR
Melbourne Australia
7Back to top Go down   Removing the battery Empty Re: Removing the battery Wed Jul 24, 2013 8:43 pm
You have to ride it there and believe me it will need cleaning when you get there.
8Back to top Go down   Removing the battery Empty Re: Removing the battery Wed Jul 24, 2013 8:52 pm
JR_K100RS
JR_K100RS
Maybe we could all kick in a bit of cash to arrange a pickup , Mike I mean , shove him in a crate filled with steel wool , sunlight soap , WD40 & bronze wire wheels , then set him up in basement somewhere ? Smile
JR
Melbourne Australia
9Back to top Go down   Removing the battery Empty Re: Removing the battery Thu Jul 25, 2013 2:28 am
MikeP
MikeP
I wouldn't mind popping-down but not until after we've won the Ashes (shouldn't be long now). Wink
10Back to top Go down   Removing the battery Empty Re: Removing the battery Thu Jul 25, 2013 5:42 am
Ashes? What Ashes?
MikeP wrote:I wouldn't mind popping-down but not until after we've won the Ashes (shouldn't be long now). Wink
