1Back to top Go down   Fitting intake rubbers Empty Fitting intake rubbers Wed Jul 24, 2013 12:16 pm
brickrider
brickrider
I've ordered new rubber connectors to fit the throttle bodies to the head.  Should the connectors be fitted dry or with a sealer?  If with a sealer, which should I use?  I'd used Dirko in the past on the old rubber connectors, but they began to leak within a few months. Crying or Very sad
Man, I hate the thought of working on those things again.  Space is so tight there....  Rolling Eyes
2Back to top Go down   Fitting intake rubbers Empty Fitting intake rubbers Wed Jul 24, 2013 1:14 pm
ironbutt
ironbutt
I'll be interested in the replies for this as I have to do this when I return from my trip. I would think no sealant but maybe a lite coat of wd-40 won't
 harm the rubbers. Just my two cents. Where did you get yours from and what was the cost?
Fitting intake rubbers 1106080553
85 K100rs WB 1051307F0040102
2010 Camaro SS
3Back to top Go down   Fitting intake rubbers Empty Re: Fitting intake rubbers Wed Jul 24, 2013 1:25 pm
brickrider
brickrider
Those rubber bits are depressingly expensive at the local BMW dealer, so I ordered them from Motobins.  I figure I saved around $50 US in so doing. I just hope they are promptly shipped, as I plan to ride to Yellowstone in early August.  Surprised-o:
Fingers crossed....  Fitting intake rubbers 652573
4Back to top Go down   Fitting intake rubbers Empty Re: Fitting intake rubbers Wed Jul 24, 2013 5:31 pm
Johnser
Johnser
ironbutt wrote:I'll be interested in the replies for this as I have to do this when I return from my trip. I would think no sealant but maybe a lite coat of wd-40 won't
woah there! stay away from rubber bits with any kind of oil based lubricants. there's a good chance they'll shorten the life of it. assemble with silicone grease if you need something to help them slip on or something like hylomar blue if you need something to help seal.
WD40 is for displacing water.
5Back to top Go down   Fitting intake rubbers Empty Fitting intake rubbers Wed Jul 24, 2013 6:10 pm
ironbutt
ironbutt
Woa K good point!
2010 Camaro SS
6Back to top Go down   Fitting intake rubbers Empty Re: Fitting intake rubbers Wed Jul 24, 2013 6:24 pm
Johnser
Johnser
ironbutt wrote:Woa K good point!
 heh - there is another branded lubricant which wont perish rubber.... or latex.Smile
7Back to top Go down   Fitting intake rubbers Empty intake rubber Wed Jul 24, 2013 7:54 pm
tezk100rs
tezk100rs
I'll be doing the same job soon and I would be looking at water inlet/outlet  pipe of same diameter from mining machinery eg Catepillar...these machines work in 40 degree centigrade heat all day everyday ..I used a Cat pipe on my pool pump and its still there 25 years later been in the sun and dosn't even look like perishing
Regards Terry
8Back to top Go down   Fitting intake rubbers Empty Fitting intake rubbers Wed Jul 24, 2013 8:15 pm
ironbutt
ironbutt
Fitting intake rubbers 44271
2010 Camaro SS
9Back to top Go down   Fitting intake rubbers Empty Re: Fitting intake rubbers Wed Jul 24, 2013 8:29 pm
Hylomar Blue or Permatex Blue will do the job.
10Back to top Go down   Fitting intake rubbers Empty Re: Fitting intake rubbers Wed Jul 24, 2013 11:35 pm
anything that is fuel resistant ...there is a fair bit of it around those places
11Back to top Go down   Fitting intake rubbers Empty intake rubbers Thu Jul 25, 2013 8:15 am
tezk100rs
tezk100rs
Catepillar rubber resists anything...but there is a problem..the top of the carburetor is 40mm and the bottom of the plastic plenum chamber is 43mm...the original BMW part may be the only answer. I will try the cat hose first
Regards Terry
12Back to top Go down   Fitting intake rubbers Empty Re: Fitting intake rubbers Mon Jul 29, 2013 11:41 am
zonenfeile
zonenfeile
tezk100rs wrote:Catepillar rubber resists anything... I will try the cat hose first
Regards Terry
lol!
Best regards from CAT Dealer in Ger.
why do we sell rubber parts for CAT all the time
btw.
the lower side of the new intake rubbers has a little sealinglip .This is supposed to do its job.
if the Rubbers are ok:
you can mount them with 3-bond from BMW (usefull stuff anyway)
prt no: 07589062376
compl. part list : Partlist K75-K1100
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
