1Back to top Go down   Help....fan problem Empty Help....fan problem Sat Aug 10, 2013 4:51 pm
DeRodster
DeRodster
ok I read Inge K's various feed's , and thanks for them Inge.
My fan is not running.
It was stuck but I freed it up and it is not moving freely.
I ran the engine until it was nearly in the red but fan not running.
Is it a case of removing tank to get at relay.
Can I get at the fan connector by removing the right side lower fairing.
ta
Rod
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   Help....fan problem Empty Re: Help....fan problem Sat Aug 10, 2013 6:58 pm
On a K11, you find the fan connector under the tank.
Since the fan was stuck, have you checked the fuse?
Easy check, horn test, same fuse....
The Motronic unit grounds the relay coil via pin 2.
Could also be a idea to check the temp sensor/connections, pin 21 and 32...
compare with the temp/resistance values found in the troubleshooting diagram
at the portal.
From Flying Brick:
Help....fan problem Motron11
3Back to top Go down   Help....fan problem Empty Re: Help....fan problem Sun Aug 11, 2013 3:03 am
DeRodster
DeRodster
Hi Inge,
Yep fuse and horn all good.
So will continue check's as you have said.
Many thanks
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
4Back to top Go down   Help....fan problem Empty Re: Help....fan problem Mon Aug 12, 2013 4:39 pm
DeRodster
DeRodster
I found the fan connector under the tank.
tried 12v on it and nothing happens.
Am pretty sure it's the correct connector and wire's go straight to motor.
so looks like a new fan ....
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
5Back to top Go down   Help....fan problem Empty Re: Help....fan problem Mon Aug 12, 2013 5:20 pm
I have a K100 fan sitting in my shed if it is the same one. Got it from Motorworks in February. No need for it as it was for the K100 which is now off road.
Olaf
6Back to top Go down   Help....fan problem Empty Re: Help....fan problem Mon Aug 12, 2013 5:23 pm
DeRodster
DeRodster
Thanks Olaf,
I'll check and get back to you
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
7Back to top Go down   Help....fan problem Empty Re: Help....fan problem Mon Aug 12, 2013 5:34 pm
DeRodster
DeRodster
hi Olaf.
Is it ENA60427
Seems to be same for K75 K100 and K1100
Looks like we might have a go.
I just want to check the motor before I finally write it off.
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
8Back to top Go down   Help....fan problem Empty Re: Help....fan problem Mon Aug 12, 2013 7:21 pm
DeRodster wrote:I just want to check the motor before I finally write it off.
Rod
 Common problem is fried brush holders........
9Back to top Go down   Help....fan problem Empty Re: Help....fan problem Mon Aug 12, 2013 8:07 pm
DeRodster
DeRodster
Yes Inge,
I was coming to that idea myself.
It seems as if one brush is in contact as I can hear it but with 12v on the connector....zilch.
what a pity.
I got the back off the fan motor but it is impossible to remove it completely without moving the radiator forward......
so I will leave it for now and put it all back together for the weekend coming.
Then we will see what to do
adios
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
10Back to top Go down   Help....fan problem Empty Re: Help....fan problem Mon Aug 12, 2013 8:09 pm
Rod,
I am away all day Tuesday, heading to Limerick early for 9am meeting and taking the bike. I could get it in post on Wednesday or could take it some of the way up........
The fan is only really an issue if you are sitting or idling in traffic. Once moving the fan is not used. I was able to keep the K out of the red by cutting the engine in heavy traffic. If you have a temperature gauge you could probably manage this quite well. If the weather is not as hot as recently and you are doing a straight run with little slow driving you will probably get by.
I will PM my mobile.
Olaf.
11Back to top Go down   Help....fan problem Empty Re: Help....fan problem Mon Aug 12, 2013 8:36 pm
DeRodster
DeRodster
Hi olaf,
tks for the pm and I replied. will call you Wed.
Indeed it's only been noticeable lately in the warm weather....certainly I did'nt notice it before.
At least I know what it is now.
just got to avoid stopping and traffic lights...that'll be more fun anyway
ride on
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
