1Back to top Go down   Lifting K1100lt fuel tank Empty Lifting K1100lt fuel tank Tue Sep 25, 2012 12:58 pm
DeRodster
DeRodster
Hi All,
I wonder if someone can point me in the right direction.
I don't see any clips or bolts so I guess its a case of lift firmly.
I did see it done a while ago but cant remember exactly what the man said
as I was on a steep learning curve.
I think just lift and slide back slightly, as I want to check something up front.
ta
Rod
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Tue Sep 25, 2012 1:41 pm
Lifting K1100lt fuel tank Tank10
3Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Tue Sep 25, 2012 1:51 pm
"Ingepedia" strikes again. He beat me to it Derodster!
Lifting K1100lt fuel tank Ir-log1188....May contain nuts!Lifting K1100lt fuel tank Ir-log11
K75RTP - 1994
4Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Tue Sep 25, 2012 1:55 pm
If you need to disconnect the fuel lines, remove fuse #6 (fuel pump) run the bike untill it stops.........then it`s no pressure in the lines when disconnecting.......
5Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Tue Sep 25, 2012 2:38 pm
DeRodster
DeRodster
Brilliant
Thanks Inge
I'll have a looksee later
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
6Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Tue Sep 25, 2012 2:40 pm
DeRodster
DeRodster
and i should have said, I wont be taking it off.
At least not this time anyway ;-)
I just need to lift it to get a cable out of the way.
Previous owner had an Autocom fitted.
I don't need it at the moment so am removing.
R
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
7Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Tue Sep 25, 2012 3:51 pm
I am not sure how far you can pull it back without disconnecting the fuel lines. I put longer fuel lines in to allow that to happen, just keep an eye on them. My original ones were a bit perished so I just put in the longer ones then. I also relocated the fuel tank earth.
Be careful removing the wires, you may disturb connections then end up taking off the tank to find which one is gone wrong. How do I know? My advice, take tank off.
Mine is a little different as its K100LT. And I have no clips.
Last edited by 92KK K100LT 193214 on Wed Sep 26, 2012 4:40 am; edited 1 time in total
8Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Wed Sep 26, 2012 3:35 am
DeRodster
DeRodster
Yep all ok.
No problem except the rubber grommit on the left side rear locating pin was a devil to get off.
In the end I realised the wire was caught in the side panel bracket rather than under the tank.
However I seem to have lost the one remaining tank retaining clip, so its on the list for a new pair.
Rod ;-)
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
9Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Wed Sep 26, 2012 4:04 am
What! and be the only K in existance with clips holding the tank on.
10Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Wed Sep 26, 2012 4:05 am
DeRodster wrote:Yep all ok.
Rod ;-)
No need to go overboard there Rod. You could probably count on one finger the number of folks who have those clips.
Actually probably 3 fingers. You, Alex and his police bike and Halo when he gets to putting the tank on.
I did not even know there were clips till I read it here. Only took me 19 years to find out.
rossco
edit. Damn Rick beat me to it.
Last edited by rossco on Wed Sep 26, 2012 4:05 am; edited 1 time in total (Reason for editing : too slow to post)
11Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Wed Sep 26, 2012 5:33 am
DeRodster
DeRodster
I know, I know, so i'll just stick with the one then.
Be a pity to lose the tank in a gust of wind or somethin ;-)
particularly the way the wx is just now
R
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
12Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Wed Sep 26, 2012 4:07 pm
Count halo out, rossco, he has an '84 so it will be a proper tank mounting. (Before they cheapened them Lifting K1100lt fuel tank 652573 )
13Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Wed Sep 26, 2012 4:31 pm
JGT
JGT
I joined both clips together with a length of electrical cable. Pull the cable, both clips pop off and you dont loose em. John.
14Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Wed Sep 26, 2012 4:47 pm
DeRodster
DeRodster
Very clever.
I'll remember that one when I get the other clip.
found the one I lost yesterday...sitting don on the gearbox casing.
took her out for a spin into Maynooth earlier , went grand 'till i just got to the outskirts then something went pop and I lost a bit of power....felt like one of the plug caps came off and she was running real rough....power came back after a few moments so I took her home .
Was all right all the way....
Strange...
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
DeRodster
DeRodster
Hi Inge et al,
I want to lift tank out to get at the fan connector. Have taken off lower fairing, radio, fuel gauge and temperature gauge. Wont start ! is this because the gauge is disconnected or ?
I only want to start it to de-pressurise the fuel line, if I don't am I likely to have gallons of petrol spraying about the place ?
I will empty the tank before I do it anyway.
I did lift the rear last time but this time I would like to take the tank out completely. From the diagram it looks like I will have to disconnect fuel line 2 and 3  and the two plugs 4.
I would imagine the tank has not been off since before 2004 so is it likely to be a little sticky on the front lugs ?
Any advice appreciated
ta
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
16Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Mon Aug 12, 2013 8:31 am
You can lift the tank back then up a good way, much futher than the K100 as the fuel lines go from the inlet and outlet back to the rear of the fuel rail.
If you want it right of then open the cap to depressurize the tank and remove the fuel lines ,put a short piece of fuel line between the two tubes , disconnect the pumps electrical connector and the tank will come back and up and off.
With a K1100 you dont need to remove any fairing parts just be careful not to scratch the tank on the glovebox mounts.
17Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Mon Aug 12, 2013 8:35 am
Rod,
If you leave the bike overnight without turning on the ignition [which pressurises the fuel system] it loses the pressure anyway. I used to do that rather than run it dry. All you will then lose is whatever fuel is in the fuel pipes. the tank doesn't drain all over the place.
Put protective stuff down each side of the tank so you don't scratch it. Otherwise remove one side box and inner fairing to give you room.
This was a K100LT but I think all is similar.
Olaf.
18Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Mon Aug 12, 2013 3:51 pm
DeRodster
DeRodster
Thanks Lads,
that worked fine, and no need to disconnect anything.
As you say Rick G, it lifts up and back a good way so no need to disconnect any lines.
now to try identify the fan connector....quite a lot of wires down there.
I think the cable colours are (Clymer) Brown/ Violet_Yellow.
I'm going in....wish me luck
R
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
19Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Wed Aug 14, 2013 4:10 pm
xpc316e
xpc316e
I started to take my tank off this evening in order to see if I can relocate the throttle cable as the revs rise on full lock, and guess what?  Yes, my 1991 K100LT had both tank clips (and they were held together by a length of wire).  I think it shows that someone loved and cared for my bike before I bought her.
20Back to top Go down   Lifting K1100lt fuel tank Empty Re: Lifting K1100lt fuel tank Wed Aug 14, 2013 4:21 pm
DeRodster
DeRodster
Nice one and very careful previous owner.
I still have one and hope to have two one day soon.
We worry about such small things ;-)
Nice to have it right though
adios
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
