1Back to top Go down   LED Instrument Bulbs Empty LED Instrument Bulbs on Mon Aug 19, 2013 9:58 am
I've found what looks like a local ozzie source for LED Dash Bulbs if you want some.
I'm pretty sure the K100 uses T10 bulbs ->
http://www.bl-led.com.au/store/index.php?main_page=index&cPath=77_5_20_11
$3.50 a pair is pretty cheap, but remember they'll only work the right way round.
2Back to top Go down   LED Instrument Bulbs Empty Re: LED Instrument Bulbs on Mon Aug 19, 2013 10:24 am
Thats the ones, the green ones seem to work best.
3Back to top Go down   LED Instrument Bulbs Empty Re: LED Instrument Bulbs on Mon Aug 19, 2013 11:02 am
good find robin
'86 K100 RT..#0090401 ..."Gerty" ( Gertrude Von Clickandshift ) --------O%OLED Instrument Bulbs Au-log10
4Back to top Go down   LED Instrument Bulbs Empty Re: LED Instrument Bulbs on Tue Aug 20, 2013 3:29 am
how many do you need ...as in how many are there of the same type...
not counting fuel, high beam etc...
KKlompy LED Instrument Bulbs 2854237993
5Back to top Go down   LED Instrument Bulbs Empty Re: LED Instrument Bulbs on Tue Aug 20, 2013 3:45 am
There's a lot of info in this thread ->
http://www.k100-forum.com/t223-led-lights-in-the-instrument-pod-plus-sealing-out-the-moisture?highlight=instrument+bulbs
There are pics in there of the $60 + post kit you can get from the USA. It replaces all the lamps.
6Back to top Go down   LED Instrument Bulbs Empty Re: LED Instrument Bulbs on Tue Aug 20, 2013 4:42 am
there is even the instruction for directions to install into the cluster if you look carefully ....and that kinda gives you the head count klompy
but I would be sticking with the standard ...(but new incandescent bulb) for the charge indicator ...thats just what I think is good .
have installed a 4 led clear bulb in the clock module area ...which works better than the old bulb and green condom  ....for me at least
