1Back to top Go down   Fuel Cap Orientation 1987 K100RS/RT Empty Fuel Cap Orientation 1987 K100RS/RT on Wed Sep 11, 2013 12:49 pm
Shep
Shep
Can you simply turn the fuel cap 180 degrees to open to the rear rather than to the front?
This is a question regarding a 1987 K100RS and 1987 K100RT 8V.
Shep
2Back to top Go down   Fuel Cap Orientation 1987 K100RS/RT Empty Re: Fuel Cap Orientation 1987 K100RS/RT on Wed Sep 11, 2013 2:51 pm
zonenfeile
zonenfeile
think that might cause probs with :
1.  Tank air (breathing ?? Embarassed  ) hole
2.   Waterdrain hole & pipe
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
3Back to top Go down   Fuel Cap Orientation 1987 K100RS/RT Empty Re: Fuel Cap Orientation 1987 K100RS/RT on Wed Sep 11, 2013 4:20 pm
The tank doesn't breath through the cap, Olaf, there's a drain/overflow pipe which exits through the bottom of the tank that acts as the breather.
Turning the cap will cover the water drain hole though.
 If you really must turn it, Shep, then drilling a new drain hole opposite the existing hole should  work.
4Back to top Go down   Fuel Cap Orientation 1987 K100RS/RT Empty Re: Fuel Cap Orientation 1987 K100RS/RT on Wed Sep 11, 2013 4:37 pm
MikeP
MikeP
Swapping the side prop to the opposite side will help too. Wink
1992 K1
5Back to top Go down   Fuel Cap Orientation 1987 K100RS/RT Empty Re: Fuel Cap Orientation 1987 K100RS/RT on Wed Sep 11, 2013 5:11 pm
@MikeP wrote:Swapping the side prop to the opposite side will help too. Wink
I often wondered about that. I was working on a shopping centre with an Architect and he designed some motorcycle parking bays on the left of the traffic up against a wall. He had trouble understanding that it would not work because one always exits a motorbike on the left and you need space so the bikes would end up out in the traffic lane. He actually thought you could put a stand down either side.
1997 K1100LT 0188024 Wotan Mystic Red 58,645 now 98,780 miles
1983 K100RS 0011171 Fricka 29,495 miles Damn K Pox Its a Bat outta Hell No 32,600 miles
6Back to top Go down   Fuel Cap Orientation 1987 K100RS/RT Empty Re: Fuel Cap Orientation 1987 K100RS/RT on Wed Sep 11, 2013 5:15 pm
Quote 92
'He actually thought you could put a stand down on either side'
You can on a Vincent! Fuel Cap Orientation 1987 K100RS/RT 39723
7Back to top Go down   Fuel Cap Orientation 1987 K100RS/RT Empty Re: Fuel Cap Orientation 1987 K100RS/RT on Wed Sep 11, 2013 7:29 pm
the.postman
I use to have a little honda 125 trails that had a side stand on both sides, it was designed for hill farmers so you could park easily on hills.
1984 srx 600
1986 cbr1000f/h
8Back to top Go down   Fuel Cap Orientation 1987 K100RS/RT Empty Re: Fuel Cap Orientation 1987 K100RS/RT on Wed Sep 11, 2013 7:57 pm
Shep
Shep
Thank you
